oinkoink1999
Question On Kitchen Hood
Hi forummers,
I'm contemplating whether to install kitchen hood for my new flat because in my current flat, i have instaled one but seldom or never use it at all..can i check if any of you really turn on when you are cooking...is it really that effective or just for the beauty of it?
another technical question is after sucking the smoke into the chimney...where does it goes to in the end?
Any comments? I was thinking of replacing the hood with additional cabinets so I can have more storage.....
cheers,
oinkoink
Hi forummers,
cheers,
oinkoink
I have not used one previously
but will still get one for the new place to avoid having to dismantle the top cabinets in future should i change my mind
for HDB, only recycling models are allowed
so the fumes pass thru the filters and get circulated out again into the kitchen
for chimney hoods, you will see air vents on the chimney, that's where the air gets released
in terms of effectiveness, i have only heard of Fujioh one being effective
the downside is that designs are not pleasing to the eye
to test suction power:
for Fujioh, go to Hoe Kee at IMM
for Rinnai / Ellane / Turbo, go to CityGas gallery at Somerset
for Brandt / Bosch, go to Rina Electrical at Lido building
Edited by bobztoise
Hi forummers,
cheers,
oinkoink
hey, it all depends on your usage. You determine how much cooking will be done. If you enjoy cooking or got time to cook. It is better to get one. But if your kitchen will stay as good as new after 6mnths. then you do not need any hood. Or if you have 2 miserable hob, then i say it is a showroom meant for show and not usage. My take is ppl who cook will demand a decent kitchen, while ppl who dont, can cook instant noodle can liao ;)
hi all,
really appreciate all the helpful advice that you have given. My dad will do most of the cooking.. maybe 3days out of a week but his cooking is geared towards healthy lifestyle which don't require deep fried or heavy cooking....anyway, I will think about it...my understanding is that the hood maybe used initially but after a while ppl dont on it anymore...
thanks~!
oinkoink
hi all,
thanks~!
oinkoink
actually if there is hardly any heavy cooking or deep frying, you may want to consider ceramic hobs..
according to the demos i have seen, they produce less fumes yet produce high heat within shorter times
with less fumes, not having a hood is probably fine
hi bobtztoise,
whats a ceramic hob? Any website or pictures that I can see?
oinkoink
hi bobtztoise,
oinkoink
I'm sure you have seen it before
Ceramic Hob
Works on almost any kind of pots
Red ring indicates heat is on
Temperature auto moderates to desired level
Induction Hob
Works only on "induction-able" pots
i.e. no aluminium, no claypots, no teflon pots
Pot does not heat up so you can touch the edges and top of the pot and still not scald yourself in most cases
Heat gets transmitted into contents of the pot so cooking time is reduced
any kitchen experts, correct me if i am wrong
Edited by bobztoise
hi all,
thanks~!
oinkoink
imo, if only doing light cooking, no real need for a hood. But then again, may be good to install one just in case your needs and preferences change. In any case, you can buy a slim line hood. This way, you will not compromise on the top cabinet space.
hi froggy & bobztoise,
thanks for the suggestion. I know what is a ceramic hob already. Went to Hoe Kee to see the fujioh demo. I will get that set.
So bobztoise...tomorrow collect keys already...must be excited...
cheers
oinkoink
cheers
oinkoink
i use the hood everytime i cook... though the recycle type allowed in HDB may not be the most powerful, it's effective enough for me especially for the cooking smell... once the hood is on, smell will be gone pretty soon.
at first i wanna get the Fujioh hood too but after learning that you have to screw/unscrew to clean the interior, i dropped the idea and purchase another one instead, which uses carbon filter and it's less hassle to clean :lol:
cheers
oinkoink
Yes... finally... less than 24 hours to keys...
by the way, marshmallow is right; try removing the cover for cleaning before you commit the purchase
it is indeed a little tricky
it would be good to check out a few more models
perhaps you can make a trip to CityGas gallery, more models to test but do not buy there as the prices are high and fixed
hi bobztoise,
how was yr unit...r u facing the civil service college? btw is there a website for ellane? i saw u got a pair of them..is it good?
oinkoink
