bepgof
Distribution Of "chi"
We understand that mass & energy are interchangeable.
One school teaches that only "living things" generate "chi".
Another school of thought teaches that "chi" can be in the form of matter or energy or a combination of both. Therefore, chi can be either visible, invisible, or partially visible and partially invisible.
What do you think which is more chun(correct)?
Ancient chinese classified all things in nature into 5 elements: metal, wood, water, fire, and earth. All things are a combination of these primary bases, therefore different combination have different influences; ie some are fortunate and some are evil (situational dependant). "Chi" is the contributor to "fortunate" ? as well as the culprit to the "evil"(Sha)? How to know it is a "sha",situational dependant also, or all time "real"?
Edited by bepgof
Sir, I raise my hand to ask a question:
1. Everything in my house eg furniture are static (we don't move furniture here or there). Except human moving. So how can i know which location of my house have generated Chi or degeneated Chi ? Can i say "weather change" will generate Chi as well ?
We understand that all matters radiate out energy in form of "radio waves", and, after many year of radiation, the matters change state to another matter. Radio active materials generate radio waves (these waves with different "penetration" power) that deform living things' basic cell-structure....Pls read physic & chemistry if want to know further.
These "radio waves", to my personal understanding and believe, are "qi". Any other opionions ?
We don't shift heavy furniture here & that everyday/month/year. We "bring in", "throw away", and "move" around objects to/within residentiial unit. I therefore said qi i is dynamic and changes every nano second. Weather change will change chi too.
One big doubt remain uncertain (not sure) is, how to know which qi is good and which is bad. And, is it "bad" ones will remain bad under all situations, or put it another way, this chi bad to A, but good to B, possible? - Another question for Master Tong, ok?.
Edited by bepgof
Qi is dispersed by the wind and gathers at the boundary of water.
The core foundation of Feng Shui focuses on the existence of “Qi” or life force which is believed to permeate in our living environment.
In the study of Chinese Metaphysic, every home is demarcated into 8 palaces or sectors according to the system known as Eight Mansions (BaZhai). So, your house can either be East Group or West Group house. Each group has 4 auspicious and 4 inauspicious sectors within the house.
If the external landform within the vicinity of our house is conducive, Qi will be able to enter the house through the main entrance of the house.
Our home is regarded as a container of Qi and the 8 sectors of the house are either auspicious or inauspicious depending on where positive Qi or negative Qi collects. So, auspicious sectors will bring good luck to the residents whereas the inauspicious sectors, bad tidings.
:paint:
I moved my furniture around every now and then, do a minor spring cleaning to activate good Qi. For this reason, I cannot lay parquet flooring in the rooms, as there would be scratches.
Electrical appliances like TV, fan and radio are considered 'Qi activator' and we must be mindful of their placement.
How would (what are) you view as to placement of stove right opposite sink, with human moving in the kitchen vs shop owner who sells many of these 2 kinds together wihin the shop, effects to owner & shoppers?
Edited by bepgof
:paint:
For mere discussion, not "shooting", wording may appear a bit fierce.
In other words, can I say you believe "more" that non-livings generate qi too than "only livings" generate qi? Taoism stresses only living things generate qi.
- Why fs's qi likes water so much?
- Through main door only? windows, gaps? back doors, side doors no chance?
- Anyway to "know/detect/sense" qi is retained, via "smooth", "not smooth" of events taking place.
Edited by bepgof
Good question raised by bepgof - i will put into my question list.
mae29 : Eight Mansions (BaZhai) - is it FIXED that there will be 4 good and 4 bad "equally" each time ?. Is that why fs master put objects to maximise good and minimise bad ? sorry i m not expert, but i try to think in layman terms.
beogof,
So long as their food is yummy & has a long long Q & business is good, then nobody would be bothered with the fire & water opposing each other.
By the way, I noticed that becox the environment inside the food stalls r really heated up with little ventilation, there r bound to be quarrels between hawkers & whoever whose helping out inside the stall. The common scene is a male hawker quarreling with his wife whose assisting him. :furious:
So, even if the stove & sink aren't facing each other, they'll still quarrel in view of irritation. Running a food business is a very tough job. Not easy.
Edited by edenstrauss
kalimantan,
I think u better prioritise all your questions for master nong. I can see a huge pile of question marks waiting to crash down on him already leh :P
If he tells u that he need to go off before u finish asking him all ur questions, then oops, u might miss out the most important. So u better prioritise the more important & critical ones just in case this happens.
:rolleyes:
kalimantan,
:rolleyes:
agreed. First to ask is "unlock my bazi and unlock my wealth"
When we evaluate external forms, things like sharp electrical pylons, 'Bo-tak' Unhealthy mountain, dirty murky water are example of bad Qi which we do not like to receive, either at front door, side door, or whichever openings or view from the windows. It will be even detrimental if confronted with bad flying stars residing at that sector.
Dark, long corridors are also not conducive, and we do not want beams running across the main door. Ofcourse, some of you already aware that we cannot place stove & water in confronting direction, etc etc.
It will only activated if you start cooking and washing...as you mentioned, human being is the Qi carrier too.
We need to bear in mind that this does not mean all houses will have 4 inauspicious sectors and become HALF bad house! :o
There is always remedy and cure in the form of enhancements.
Good sectors are utilised for areas where we spend most of our time, like Bedrooms.
