Hi all forummers,
I have shortlisted two IDs and they both gave me good pricing and design. Just would like to hear from all which ID has a better quote in your opinion. My unit is a new 5room HDB flat with floor area 115sqm.
ID1
Carpentry Works
Living area
01) To construct full height partition TV feature wall come with paint finishing
02) To design and build within L 8ft suspended TV console using laminate finishing as per design
03) To construct full height open niche display using partition board and paint finishing
04) To design and build within L 7.5ft settee come with PVC cushion and and drawer using laminate
05) To design and build within L 6ft full height shoe cabinet come with black mirror sliding door as per design
Plumbing Works [Exclude Sanitary ware ]
01) Labour to install 2 bathroom sink
02) Labour to install kitchen sink
03) To extend inlet & outlet pipe for kitchen sink
Ceiling Works
01) To supply and install false ceiling **** hall
02) To supply and install false ceiling at study room
03) To supply and install false ceiling at master room
Electrical Works
01) Light point
02) light fitting [ lighting by owner ]
Painting Works
01) Paint whole unit wall and ceiling. [ ICI / Nippon ]
02) Paint whole unit water pipe.
03) Paint whole all doors and frame
04) Paint main Gate
Wall Paper
01) To supply and lay heavy duty imported wall paper at master room , bedroom 2 and 3 bed area one side
wall only as per design [ within L 13ft ] [ subject to stock ]
Kitchen Works
01) To supply and install WITHIN L25Ft Bottom Designer kitchen cabinet completed with:
a) Laminate finishing
b) Solid door with ABS trimming
c) Silent motion sliding track for 3 drawer
d) Cutlery tray
e) Labour Install cooker Hood and Hob
02) To supply and install within L12.5ft solid surface top
TOTAL: $35,000
ID2
Demolition & Masonry Works
01. Hack off existing wall at between Dining & kitchen
02. Hack off existing small position floor tiles at kitchen
03. Supply materials & labour to touch up damages after hacking
04. To supply materials & labour to lay Polish Homogeneous tiles ( ≤$ 3.00 TO $3.50/ sqft ) with
skirting ****, Dining, Walkway, Master Room, Room 2 & Room 3 floor.
05. To supply materials & labour to lay Polish Homogeneous tiles ( ≤$ 3.00 TO $3.50/ sqft ) with
skirting at Household shelter floor.
06. To supply materials & labour to construct H50mm cabinet base, side with tiles finish only.
07. To supply materials & labour to construct H50mm fridge base with tiles finish.
08. To supply materials & labour to construct H50mm washing machine base with tiles finish.
09. To supply materials & labour to construct 02 nos H50mm shower kerb at Master Bathroom
& Common Bathroom
Plumbing Works
01. To supply materials & labour to extend existing copper pipe to new sink
02. To supply materials & labour to install concealed drainage pipe for new sink
03. To supply labour to install 02 nos toilet bowl spray gun at Master Bathroom &
Common Bathroom.
04. To supply labour to install 01 nos storage heater at Bathroom
05. To supply labour to install Kitchen sink & tap after carpentry work.
06. To supply labour to install Bathrooms' accessories.
Aluminium / Wrought Iron Works
01. Supply materials & labour to install N.A colour aluminium sliding window in Normal glass finish
at service yard ( L 2800mm x Ht 1500mm )( 2way track )
02. Supply materials & labour to install N.A colour aluminium window grilles ****, Dining,
3 bedrooms, kitchen & service yard ( Ht 3ft )
Ceiling / Plasterboard / Partition Works
01. Supply materials & labour to install light pelmet holder **** & Dining
02. Supply materials & labour to install plasterboard false ceiling ****, Dining & bedroom
passage way
03. Supply materials & labour to install curtain pelmet holder **** & Dining
04. Supply materials & labour to install plasterboard false wall at between Living & Study area
( L 3400mm x Ht 1980mm )
Mirror & Glass Works
01. To supply materials & labour to install Clear Mirror at Dining Area ( L 2050mm x Ht 1670mm )
02. To supply materials & labour to install CLEAR Mirror at Master Bathroom
03. Supply materials & labour to install 10mm tempered frameless glass shower screen at
Master Bathroom
04. Supply materials & labour to install 10mm tempered frameless glass shower screen at
Common Bathroom
05. Supply materials & labour to install 10mm tempered frameless glass swing door c/w
handles & hinges at kitchen entrance ( L 900mm x Ht 2100mm )
06. Supply materials & labour to install FIXED panel 10mm tempered frameless glass at
kitchen entrance
07. Supply materials & labour to install 10mm FIXED panel tempered frameless glass
at between Living & Study area ( L 3400mm x Ht 460mm )
Door / Timber / Laminate Works
01. To supply materials & labour to install 5 nos panels swing veneer doors, inclusive of
Lever lockset & magnetic door catch at Master Room, Room 2, Room 3, Master Bsthroom
& Common Bathroom( ELEGANT SERIES )
Miscellaneous
01. To supply materials & labour to paint whole house ceiling & wall using ICI emulsion paint.
02. To supply materials & labour to paint whole house gate, door, door frame, pipe & etc
using ICI gloss paint.
Budgetary Carpentry Quotation ( Prices are subjected to change at final design & material stage )
Living/ Dining
01. Design, fabricate & install shoe cabinet in laminate & white PVC carcass finish at Foyer Area.
Size: L 1200mm x Ht 2400mm
02. Design, fabricate & install Folding door in laminate & heavy duty top hung track finish at
New Study room
Size : L 3800mm x Ht 2400mm
03. Design, fabricate & install suspended TV console in laminate finish **** Area.
04. Design, fabricate & install 2 nos Tall unit cabinet in laminate finish **** Area.
Size: L 300mm each x Ht 2100mm
05. Design, fabricate & install Dining table in laminate finish at Dining Area.
Size: L 2000mm x W 800mm x Ht 760mm
06. Design, fabricate & install Low Bench cum storage in laminate & white PVC carcass finish at
Dining Area.
Size: L 1800mm x Ht 450mm
Master Bedroom
01. Design, fabricate & install "King" size bedframe c/w storage in laminate & white PVC carcass
finish.
02. Design, fabricate & install sliding door built-in-wardrobe in laminate, glass or Mirror & white PVC
carcass finish.
Size:L 5800mm X Full Height
Room 2
01. Design, fabricate & install built-in-wardrobe c/w swing door panel in laminate & white PVC
carcass finish.
Master Bathroom
01. To supply materials & labour to install solid surface for vanity top ( L 1600mm )
02. Design, fabricate & install suspended vanity cabinet in laminate finish.
03. To supply & install Mirror with light pelmet holder at vanity area
Kitchen
01. Design, fabricate & install TOP unit kitchen cabinet with laminate & white PVC carcass
finish c/w ABS trimmings & cutlery tray.
02. Design, fabricate & install BOTTOM unit kitchen cabinet with laminate & white PVC carcass
03. To supply & install Solid-Surface Worktop ( L 12.5ft )
04. Supply & install 1 set of 2 ties stainless steel dish rack
TOTAL: $38,328
Some of the items ID1 has but ID2 doesn't and vice versa.
Hope can get some feedback from all forummers out there. Thanks so much~!
