delapompe
金窝,银窝,也比不上自己的狗窝 :)
I'll cut everything short and sweet.. Floor plan attached ;)
Loads of research and purchases had been done up to 90%. Is our first time owing a new HDB apartment, what an experience.. Please give advises if necessary, kum sia.. :D
Just to share my quote from my contractor. Very efficient and responsible :sport-smiley-004:
Professional services
- Design consultation & space planning
- Design proposal & 3D perspective drawing
- Selection of colors, materials and accessories
- Site coordination & supervision
- Advice on decoration
Haulage materials & renovation debris
- Haulage & debris removal
- Applying HDB renovation permit
Masonary & flooring works
- Supply & construct cement motar base for kitchen cabinet c/w side tiling
- Supply & construct cement motar base for fridge c/w tiling
- Supply & construct cement motar base for washer c/w tiling
- Supply materials & labor including sand & cement to construct 50mm kerb at common bathroom
- Supply materials & labor including sand & cement to construct 50mm kerb at master bathroom
Ceiling works and painting works
- Supply & install plaster ceiling living area
- Supply & install plaster ceiling at dining area
- Supply & install plaster ceiling at bedroom passageway
- Supply & install plaster ceiling at master bedroom
- Supply & install plaster ceiling at common bedroom
- Supply & install plaster ceiling at kitchen
- Supply & install curtain pelmet living/master/common bedroom
- Supply materials and labor to box-up aircon trunking at common bedroom
- Supply materials and labor to box-up gas piping at kitchen
- Supply labor to install curtain rod
Plumbing works
- Supply & extend stainless steel piping for kitchen sink
- Supply & run joint in/outlet pipe for kitchen sink
- Supply & lay outlet piping for washer
- Supply labor to install storage heater at master bathroom
- Supply labor to install 2 sets of bathroom accessories
- Supply labor to install kitchen accessories
- Supply labor to install kitchen sink & tap
Carpentry works for kitchen
- Design, fabricate & install 20ft length kitchen cabinets in laminate finish comes with ABS trimming
- 1no. of chrome dish rack
- 1no. of aluminum frame frosted glass door
- 1no. of cutlery tray
- Supply & install anti-slam systems for kitchen drawers
- Supply & install 12.5ft length solid surface worktop
- Supply labor to install cooker hob & hood
- Supply & install 6ft tampered spray-paint glass backing
- Supply & install 6ft full height spray-paint glass feature wall at household shelter
Carpentry works for Living/Dining/Foyer
- Design, fabricate & install full height shoe storage/cabinet (L)3ft with external laminate & black tinted glass finish
- Design, fabricate & install 5ft TV feature wall with laminate & black tinted glass finish
- Design, fabricate & install 7ft TV console with laminate & black tinted glass finish
Carpentry works for master bedroom
- Design, fabricate & install 8ft sliding wardrobe with customized shelving with external laminate & black tinted glass finish
Carpentry works for master & common bathroom
- Supply materials & install 10mm thick wall to wall tampered glass shower screen at master bathroom
- Supply materials & install 10mm thick clear framless tampered glass shower screen at common bathroom
- Design, fabricate & install 2ft suspended vanity cabinet below master bathroom sink c/w frosted glass door, aluminum frame & laminate finish
Mirror works
- Supply materials & install 5mm thick black tinted mirror comes with plywood backing & maxbod adhesive (4.5ft x 7.5ft)
- Supply labor to install 2 sets of bathroom mirrors (120cmx96cm & 70cmx96cm)
Other works
Supply & install 9ft aluminum window grilles at serviceyard
Electricity
- Supply labor to install the following
- 25 Cove lighting
- 9 PLC lighting
- 2 Bathroom lighting
- 1 Serviceyard lighting
- 1 Household shelter lighting
- 1 Ceiling fan
Miscellaneous works
- Protection flooring with corrugated cardboard for whole unit
- Chemical wash for whole unit
- General cleaning upon completion of works
- Transporation of building materials to & from unit
Total damage S$18,340.00 :sport-smiley-018:
Edited by delapompe
Plumbing works
- Supply & install 6ft spray-paint glass backing
Mirror works
Other works
Electricity
- 25 Cove lighting
- 9 PLC lighting
- 1 Ceiling fan
Miscellaneous works
no floor works done? price looks ok to me
Aaahhh.. Some photos to share during door opening ceremony and pre-renovation :thumbs up::thumbs up::thumbs up:
2 mighty Ong Lais rolled in by us!
A mini setup to Baibai (Ritual)
Living Room
Living room door
Another view from living room
Passageway to kitchen
Walking in to kitchen
On the left of the kitchen is our mini shelter
Serviceyard door
We're shocked that this old school type of window still exist
View from master room :rolleyes:
View from living room :dribble:
Another dunno from where view :bangwall:
Many had already started and almost complete their reno and we're still halfway :bangwall:
Teehee..
Below are the plaster ceiling, cove lightings and down lighting points
Red = Plaster ceiling
Blue = Cove lightings
Yellow = PLC lights
:wub::wub::wub:
Very systematic and nice design.
Yellow = PLC lights
:wub::wub::wub:
wow, you are doing false ceiling in the kitchen!
and cove lights in all the rooms too. Nice!
Just a few thoughts --
* is one PLC light in the passage enough?
* I suppose u already have an idea how to place the fixtures? Bc that does determine where and how many lighting points. I say this bc for my kitchen, there is not much light coming in. Since we did not do false ceiling and do not want too many trunking to be seen, we can only have one lighting point provided by hdb. For all other areas of the kitchen, I have light from the top hung cabinet, so they do brighten up the area when I work at those worktops. But for the sink area, where I do most work, there is no top hung cabinet, hence no light. Keep seeing my own shadow when I work - very irritating
