wickaninsh
Amk 3 Room Reno
Question....
Any hdb homeowner do away with main gate and replace with a Digital Lock for their main door?
I'm thinking of installing a Digital Lock for the Main Door and remove the main gate
as 1 of the feature
•Burglar alarm or fire detection sensor (Above 75 degree Celsius)
Question....
as 1 of the feature
i am thinking of the same and i am going to do it that way. I got myself a samsung digital lock.
got a quotation for the below kitchen cabinet which i found is abit over priced
what r your comments?
Kitchen Cabinet(upper deck)
Design & fabricate kitchen cabinet 8 ft S$800
1 nos of aluminium frames with andblasted glass door S$145
stainless steel dish rack S$100
Spray painted glass backing 8ft S$480
Kitchen Cabinet(lower deck)
6 nos soft closing higges for casement door S$60
stainless steel tabletop 8ft S$725
total S$3110
They charging you for drawings and for carrying glass from downstairs to your unit?
yes... they do
cos mine is a 4 storey flat with no lift
carrying the glass cost abt S$900
yes... they do
Seems rather exhorbitant.
Good luck with the reno.
Question....
as 1 of the feature
i did exactly that.
for added security, i installed a burglar alarm frm Yale. bought frm Home-Fix, very cheap.
http://yalelock.co.za/en/yale/yale-Africa/...;productId=8914
where is this mounted? how does it work?
Is it activated automatically or need to switch on manually each time?
it is mentioned in product description tt this is to be mounted on door. u activate it whenever u want to arm it, even during bedtime, so tt the alarm will go off and wake u up should there be a break-in.
as far as i knw, all burglar alarms nd user to activate when leaving house in order to turn it on. even if got auto-activation, hw wld it logically work? based on opening and closing of the main door? then everytime u open and close the door, u need to key in ur pin to deactivate the alarm? imagine when entertaining and doing it for every guest who arrives. or when u just step out into the corridor and the door accidentally closes? or when you go out but a family member is staying home? if he needs to open the door, he has to deactivate the alarm? way too troublesome compared to just simply activating it whenever u want to turn it on.
