wickaninsh
Amk 3 Room Reno
I'm staying in AMK, 4 room. Ur toilet can put in the shower screen? Mine only a small one cos got no space. Can the toilet door be swing open with the shower screen there? U might want to take note of that.
U mentioned of changing the door. Is it main door? If it is, then must be fire rated if near to staircase (less than 3m away).
Get a contractor, save $. Especially if u know the colour scheme which u want.
That why i choose PD door, it can fold into halve and swing inwards
Shower screen, is not the full length & breath. More like 1/2 - 2/3....
will check with contractor/ID whether workable??????
Would like to have all similiar door, main, bedrooms & storeroom
dun think i'm less than 3m from staircase. there 2 unit before me and a corner unit after me
Will check on this too.... tks for the info
Present Living Room
The floor is those rubber tiles, so will saving on hacking
The opening to the Bedrooms is where i want to put the wooden sliding door
Dun think i want false ceiling, so the gas & water pipes need to change to steel
and electrical wiring need to change too....
Walls will need pastering to make it even
Edited by wickaninsh
Present Kitchen
The separation will moved 1metre (as suggested by gimz63251073)
and in it place the Glass Sliding Door
The walls, floor & washing basin outside common toilet will be hacked
There no built in cabinet to hack so will save on that....
Will build the new cabinet
Hi Wick,
Nice to see you have everything you wanna do in mind. Any idea how much budget you're going to work with?
Cheers
Present Kitchen
lolx
Ha ha! Yeah neubie, I like your kitchen very much too!
How much do you think your contractor will charge if I wanna just do the kitchen like yours?
without the sliding door lor...
Thinking of gething this laminated flooring from Pergostore
Maritime OaK (but this is not on offer, but they willing to gives 15% discount)
Two questions
1. will it be werid if i only use this in living room and a cheaper one for bedrooms & store room
2. can the stair on the main entrance be laminated?
yes, u can use the laminates on the entrance steps. but u need to know this before using it. that portion of the laminate will wear a lot faster and fade and look pale compared to the rest of the floor in the hall.
my layout is a little similar to urs, as in, small toilet. but in my case, the master toilet is smaller than the common. in the end, i decided against a shower screen. it would be way too cramped. oh and do not place a WC in a confined corner. u will really not like doing ur business thr. and it's not sth tt u can change easily when u realise it's too cramped to spend time doing business there. just my opinion. my toilet is my "zen" place and i like it as comfortable and luxurious as possible, but alas, my master toilet is too small to do anything nice. :(
thanks.
$8.7k just for the kitchen (excl bathroom/wc works, glass door, lightings, electrical wiring, plumbing, sink)... here's the breakdown
- hack off kitchen flooring/wall tiles ----$700
- lay floor/wall tiles + low wall + cabinet base + rubbish chute ----$5k
- top/bottom kitchen cabinet w solid surface top ----$3k
