wsnlance
Water Feature Location
Just curious, does placement of the water feature require a fengshui consultation?
some say place it beside the main door is a good location, others say place it where most of the "qi" accumulate, e.g. in the living room beside the sofa where most people gather.
so which one is recommended?
I have a few waterfall features in my home. One of which is next to the main door, such that it's on my right hand side when I enter my flat. This one has a few small fishes in it.
The other two is found inside my dining room (west) & living room (southwest). All 3 are recommended by my FS masters.
Edited by edenstrauss
If you believe fsm, engage one & see what he says. South is "fire".
If you don't believe, can put anywhere as you please. Things to consider:
- Water tap head, pipes
- Power point
- Lighting, if necessary
- Algae developed over time, esp near sunlight
- high humidity to surrounding (singapore already high enought), avoid metallic parts, mirror with mercury at back.
- long time exposure to high humidity no good to human bone.
Edited by bepgof
- Power point
So you believe in fsm or you put wherever you please?
- My body has already 70% water. Tiolets, kitchen also got much water, especially those "unwanted" humidity in tiolets. I've spent quite a while looked for mirror without mercury.
- I also bought one vacuum cleaner cum de-humidity, costs me SGD3,700, motor with 10 yr warranty.
- Late father had advised me serveral times to stay far far away from "water", as water "ke" me. Though I love swimming, sea sports...
- From my present house(#23), look out from window, can see 3 kinds of "water" - bedok reservoirs (1 big & 1 small), east coast sea and swimming pools.
- My wallet and bank accounts with "water" par par.
- So I don't require any "water feature" to be put inside house. Water, see from far ok, stand/stay near, no good lah - humidity. You'll never observe in daily life, once you observed too much this kind of "water", always too late to take actions.
Edited by bepgof
wah sounds cheem enuff, thanks everyone for the quick response.
in my simplistic mind, i just thought it looks good having a water feature at home, or the sound of flowing water is soothing to hear after a day's work... but of course concerns are that afraid if placed "wrongly" fs-wise, may not be so good after all. Would say i am a half-believer?
Do not let mind runs wild. My understanding of "water feature" as to feng shui is such:
- Moving water has "dissolving", "softening", "blending", etc effects to human minds.
- You can see many such (not those home ones), placed right in the centre of the entrance to the compound of buildings.
- Can see also at "sides" of buildings (building between building)- The condo "Baywater" is a typical example - 2 "feng shui waterball" in between buildings.
- These are believed to have the dissoving disputes, softening tension, blending characers of different kind to have good relationship. The placement at such "strategic locations" is to "remind"/"influent" ppls to be more "rounded" in term of way of doing things.
- Home? Really already too much "water", personally not recommending. Will create unnecessary tension/arguments between husband/wife/children if owner does not take care and maintain , while other occupants have to take over this duty. Same applies for rearing fish/bird......
Edited by bepgof
Thanks bepgof for the advice.. will take note and consider carefully! :)
