steelze
Sims Drive 5i
thanks for the much needed advice! i noted that ExcelHW also selling pole system for WIW. Emailed them my requirement, but havent rec their reply. Any opinion on it, neubie?
Ikea daily special
This comes a bit late. Wanna share with u guys that Ikea has this daily special promotion going on. My wishlist:
19-Dec-10
STAVE mirror @ $25
W70xL70cm. Black-brown.
(UP: $39)
23-Dec-10
FÄRGRIK 18-piece service set @ $25
Stoneware. Comprises: Plate Ø27cm, side plate Ø21cm and bowl Ø16,H7cm, 6 of each.
(UP: $42/set)
24-Dec-10
DRAGON 24-piece @ $19 (BEST DEAL!!!)
cutlery set
Stainless steel.
Comprises: Fork, knife,
spoon and teaspoon,
6 of each.
(UP: $45/set)
All above are limited to 2 pcs per customer only. CHIONG AHHHHHH~
Edited by steelze
Shopping List for Ikea
Browsing thru Ikea online catalog... shortlisted a few items for my house
BENNO TV bench with panel - $229
For my masterbed room. Cheaper substitute over the costly carpentry for feature wall and TV console
120x40x134 cm white
LOCK ceiling lamp - $3.90 **BOUGHT** (CHEAP)
For my storeroom. Cannot find any cheaper lighting than this already.
white
LILLHOLMEN ceiling/wall lamp - $16.90 **BOUGHT**
For both of my bathrooms. Like the lightbulb shaped design. Will add some classic feel to my bathrooms. woohoo~
white
FINNGRUND shower curtain - $15
Cheaper alternative for my common bathroom which doesnt have showerscreen or fixed glass panel.
180x200 cm multicolour
LILLHOLMEN toilet roll holder - $15
For both bathrooms. Cheap stainless steel holder that serve the objective well.
To be continued... ...
Ikea daily special
Bro, the bowls and plate only white ones on promotion. But quality is not bad, i bought a bowl there before, feels solid. :)
im also aiming for it...
not so sure about the forks n knifes, some ikea forks and knife really light weight (no feel)...
i like the stave mirror too, but apparantly, i already have too many mirrors! For cutlery, can try Sia Huat at Temple street (Chinatown), some of their tea cups and pots are really nice.
STOLMEN - $300+
For my WIW @ masterbed room.
stolmen--sections-white__0110248_PE26676
2 sections
Height adjustable from 82 5/8-129 7/8", which allows you to utilize the entire ceiling height.
Will be comparing with other pole system quotes as well. but ikea seems to be the cheapest, but quality wise... hmmmm... not so confident. :(
ohh.. yea.. only white ones... the DRAGON utensils not bad. my wife and i went down last month to QC the qaulity. compared to the cheapest one, these DRAGON set have smooth edges for the stainless steel. so, hopefully wont eat dinner halfway blood start pouring out... haha :bleah:
ur mirrors all from ikea? or u custom made them? I probably need a custom made mirror for my master bathroom. got cheap lobang? probably 60cm by 100cm in size.
only MBR toilet mirror not from ikea... :)
custom make mirror, ID should have lobangs, if not can try your carpenters.
from my asking around 2 shops, the real good mirrors can cost 2 to 3 times more expensive than ikea ones, with wood backing and some effects at the sides. Hence, did not consider custom ones.... and i ended up getting a good discount for ikea mirrors at the "as-is" section.
hehehehe... so typical you... always kio liulians around AS-IS section. Must learn more from you in this aspect.
goshh... since the reno started, i practically cannot concentrate in my work. mind keep thinking abt reno stuff... please faster end this period... torturing!
if your toilet is located far away from the shower area, then is ok to use this type of shelter-less holder, as water will not wet onto them.... :rolleyes:
yea... that toilet paper holder will be at a dry areain the bathroom. =)
ID just told me that for hot water point, i need to pay additional $90 for each point. I am doing for 2 shower mixers for both bathrooms, and a sink mixer for the master bathroom.
Total 3 = $270!!! Is this considered hidden costs!?!? He said quote only run cold water piping point. :bangwall: $90 for one hotwater point!? Isnt this too much? Very buay song now!
Edited by steelze
refer back to ur signed contract. does it say anything about running hot water points? if no then i would say this is overlooked by urself and addtional work constitutes variation order liao....
noo.. quote never mention anything abt water points. i browsed thru all my other quotes from various ID /contractors, none of them will quote for hot water point. is it some kind of strategies these guys are playing???
then boh pian lor, gotta pay for it lor, else no hot water.... :(
Yalor... bo bian... :bangwall:
I looked at your quote below:
PLUMBING WORKS
To supply labour to install 01 nos. of toilet bowl
To supply labour to install 01 nos. of washing basin with connect with mixer
To supply labour to install 01 nos. of instant heater
To supply labour to connect sink and mixer tap
To supply & change existing pipe to stainless steel pipe for whole unit
Which part of your item refers to the hotwater point? Or you also top up separately like me? :dunno:
PLUMBING WORKS
i'm using cold water pipes nia, so no ugly surprises there....
