booties 0 Report post Posted October 14, 2010 Hi everyone... just some quick questions. what height should a tv be placed? do you place a tv based on the height of the sofa/ bed which you are watching the tv from, or base it on the height of the console? my console is 50cm from ground to top. how much higher should i wall mount the tv? (haven't bought sofa yet) also about height of hanging lights. what should the height of a hanging light be in the living room area? does this differ from the height in the dining area? if you want to put those cluster of 3 hanging lights in the living area, what is the recommended height? my ceiling is 3m in height thanks for viewing/ suggestions. Share this post Link to post Share on other sites
booties 0 Report post Posted October 15, 2010 Hi everyone... just some quick questions. what height should a tv be placed? do you place a tv based on the height of the sofa/ bed which you are watching the tv from, or base it on the height of the console? my console is 50cm from ground to top. how much higher should i wall mount the tv? (haven't bought sofa yet) also about height of hanging lights. what should the height of a hanging light be in the living room area? does this differ from the height in the dining area? if you want to put those cluster of 3 hanging lights in the living area, what is the recommended height? my ceiling is 3m in height thanks for viewing/ suggestions. Any suggestions? Share this post Link to post Share on other sites
therat 18 Report post Posted October 15, 2010 For the TV, where you sit to watch it? Base on the sofa / bed la. Share this post Link to post Share on other sites
bepgof 20 Report post Posted October 15, 2010 (edited) Any suggestions? Me again. Hope the nails issue won't bother you much. Mounting height for tv is relative to: - Distance from viewing. - screen size. Rule of thumb(Home): when seated upright, one's eye ball facing centre of screen, so neck need not to tilt upward. Can't suggest you anything abt hanging light, no experience. Edited October 15, 2010 by bepgof Share this post Link to post Share on other sites
vicenzo70 0 Report post Posted October 15, 2010 Hi everyone... just some quick questions. what height should a tv be placed? do you place a tv based on the height of the sofa/ bed which you are watching the tv from, or base it on the height of the console? my console is 50cm from ground to top. how much higher should i wall mount the tv? (haven't bought sofa yet) also about height of hanging lights. what should the height of a hanging light be in the living room area? does this differ from the height in the dining area? if you want to put those cluster of 3 hanging lights in the living area, what is the recommended height? my ceiling is 3m in height thanks for viewing/ suggestions. Just google lah. Loads of info. Anyway, TV placement is own preference. Different strokes for different folks. Here's a sample website below for suggested TV placement. http://www.crutchfield.com/S-GXJQmxbGvyo/l..._placement.html cheers Share this post Link to post Share on other sites
booties 0 Report post Posted October 15, 2010 Me again. Hope the nails issue won't bother you much. Mounting height for tv is relative to: - Distance from viewing. - screen size. Rule of thumb(Home): when seated upright, one's eye ball facing centre of screen, so neck need not to tilt upward. Can't suggest you anything abt hanging light, no experience. no worries, the nails have been removed, its basically just to ward off evil. the Indian priest was saying, if i don't believe also no use. so no effects there. Share this post Link to post Share on other sites
booties 0 Report post Posted October 15, 2010 Just google lah. Loads of info. Anyway, TV placement is own preference. Different strokes for different folks. Here's a sample website below for suggested TV placement. http://www.crutchfield.com/S-GXJQmxbGvyo/l..._placement.html cheers thanks vincenzo. Share this post Link to post Share on other sites
