prettyinpink
Designer Veneer Doors Vs Solid Wood Door
Can anybody tell me the pros and cons of designer veneer door vs solid wood door, other than the designs which is better for designer veneer ?
Specifically, which is more prone to chipping and also to termites ?
Solid wood, while stronger are subjected to shrinking issue if the timber are not well dry before making the door. They are more expensive and in case if its dented, it can be sand and re-varnish.
All the pro of the solid door are cons of veneer, vice versa.
