leechaorui
Room That Is In-between 2 Toilets
If one has a bedroom that is sandwiched between 2 toilets, what is the FS prognosis? If the belief is bad, how to cure?
I'm the sort frequent tiolet, if bedroom in between 2 tiolets, lagi best. I would make each tiolet a door, lead to bedroom, so I can choose which tiolet to use. Tiolet with 2 doors must have interlocking feature built-in, otherwise when doing business half way, another door kena open, how? This is more important.
If tiolets are "bad" in house, suggest to knock down all tiolets and convert to become storeroom. Use tiolet at coffee shop, let the coffee shop "suay".
封建思想要不得。
Edited by bepgof
Hi leechaorui,
have u ever tried checking it out with your FS master?
Apart from the bedroom bring sandwiched in between 2 toilets, there are many considerations to make when u get your flat audited for FS purposes.
It's recommended that U check this out with a skillful FS master instead of looking for your own cures. I have seen friends with similar FS issues for their premises but even the same FS master might institute a different "cure" because FS recommendations should be integrated as a holistic approach, not fragmented & stand-alone "cures".
Hi.. i only heard if any bedrooms tat faces directly toilet will be bad. other tat i think u would like to consult experience FSM if u experience any bad happening for u or family... act fast n resolve e problem quickly rather than is too late... just my 2 cents.. hope this helps....
