kelvinangsw
Kitchen Sliding Door
Hi Folks,
Does anyone know where to buy and install this type of Kitchen Sliding door? And also roughly how much it will cost?
It is the hanging type with tempered glass. Thanks :)
Hi Folks,
Anyone has any idea where to get this type of tempered glass sliding door....
I believe I have the exact same sliding door, except that it's bigger.
40945_421530706510_556136510_5344318_230
Top-hung, same mechanism, 12mm thick tempered glass, very heavy.
Will pm you the contact.
Good luck!
Good luck!
Thanks. I have received your PM. Price is rather reasonably for such big sliding tempered glass door. :)
Can pls PM me the contact too? Thanks!
May I ask if sliding glass door works OK to keep the smell from the kitchen from "escaping" to the whole house? Cos sliding doors sure have gaps.
I do like to cook often so don't want the whole house smelling like food after each cooking session.. I will keep kitchen door open most of the time so intending to get sliding door than a swing door (which I know can close and "seal" the kitchen)
I think there will be a gap under the doors. I know you can lay some alignment at the floor but they will be protruding out. Logically, smoke and smell should move upwards out from the kitchen window...
Good luck!
Do PM me pls. Ths
Good luck!
Hi, can you pm me the contact and the price you paid for the door? Thanks!
Recently got a quote from Pdoor for kitchen, width about 900mm, price was $445 for a standard type door....sounds kinda expensive based off forummers here....range saw was about $340 to $380.
Also saw bad comments about them, poor service & installation & door not durable....so am still deciding......1st look at their door seems pretty sturdy to me.
Anybody has recently used PDoors & can provide price?
