dpbandi 0 Report post Posted August 28, 2010 Hi Mine is a 5 Room HDB flat with 110 sqm.I wanted your advise on the Type of sofa set that is good for my floor plan( L -Shape or 3+2) Appreciate all your ideas and Thanks a lot for ypur time Share this post Link to post Share on other sites
MichaelAng 1 Report post Posted August 28, 2010 Hi Mine is a 5 Room HDB flat with 110 sqm.I wanted your advise on the Type of sofa set that is good for my floor plan( L -Shape or 3+2) Appreciate all your ideas and Thanks a lot for ypur time looking at the L shape of your living room and assuming you would use the part closest to the balceny for your sofa, i would think a 3+1+1 would seems more flexible in case the 2 is unable to fit in... a L shaped sofa would also have the same problem if too long.. 1 Share this post Link to post Share on other sites
SamTheMan 7 Report post Posted September 6, 2010 Hi Mine is a 5 Room HDB flat with 110 sqm.I wanted your advise on the Type of sofa set that is good for my floor plan( L -Shape or 3+2) Appreciate all your ideas and Thanks a lot for ypur time It looks like you have 2.7m on the wall to place the sofa. If you have only 3 or 4 people at home get a L-Shape, if you have more people, a bit more challenging. 1 Share this post Link to post Share on other sites
