meander
Is This Quote Reasonable
Hi, can someone let me know if this quote is reasonable? I have 3 toilets at home. The size are 10ft by 4.5ft, 7ft 5" by 2ft and 3ft by 3ft 7".
The kitchen size is 7ft 4" by 7ft 4". I intend to redo the kitchen and all the toilets in the house, including hacking of the floor tiles and removing the old kitchen cabinets. Thank you.
Demolition work
to supply labour & tools to:
1) hack off existing sink & stove's concrete support at kitchen
2) dismantle existing kitchen cabinets
3) demolish top half of existing internal wall between living & kitchen
4) dismantle existing metal door frame at WC3
5) hack off existing floor and wall tiles at kitchen
6) hack off existing floor and wall tiles at WC3
7) hack off existing floor and wall tiles at WC2
8) hack off existing floor and wall tiles at WC1
9) hack off existing floor tiles at balcony
10) demolish existing long bath at WC1
11) dismantle existing sanitary wares, water pipes, wiring in 3 toilets
12) dismantle existing main entrance door & gate
total $2600
Masonry Works
To supply labour, tools & materials to:
1) make good affected areas after demolition of wall $150
2) Construct wall behind top hung kitchen Cabinet with lintol support $350
3) Extent wall at proposed fridge area $180
4) Lay selected range of wall tiles till ceiling height to kitchen $2750
5) lay water proof membrane to kitchen floors prior to laying of tiles $150
6) lay selected range of floor tiles to kitchen $900
7) construct cabinet bases c/w matching tiles finish on front edge $250
8) construct fridge base & washing machine base c/w matching tile finish $200
9) construct 50mm kt kerb at proposed storeroom area $120
10) lay selected range of wall tiles ti ceiling height to WC3 $1120
11) lay selected range of floor tile to WC3 $400
12) lay selected range of floor tile to service balcony $750
13) lay selected range of wall tiles ti ceiling height to WC2 $2100
14) lay selected range of floor tile to WC2 $450
15) 13) lay selected range of wall tiles ti ceiling height to WC1 $1380
16) lay selected range of floor tile to WC1 $450
Partition work:
construct gypsum board to form store room at kitchen $350
Plumbling
1) Re-run copper water pipe for whole house (cold pipe only) $900
2) install 3 sets of pedestal wc bowl (labour only) $240
3) install 3 sets of wash basins and taps (labour only) $180
4) Install 3 instant water heaters (labour only) $180
5) install kitchen sink & connect inlet & outlet (labour only) $120
6) Install bathroom accessories for 3 bathrooms (labour only) FOC
Carpentry works
to supply labour, tools, materials to fabricate & install the follow carpentry work, in solid plywood with laminated finish:
1) total 36ft kitchen cabinet c/w ABS edgin doors, 2 tier dish rack, cultery tray, designers handles or 45 degree edged doors & silent closed hinges $4320
2) suspended vanity cabinet c/w frosted glass doors for WC 2 (L4ft) $560
3) L4ft wall mirror c/w open shelves for WC2 $480
4) suspended vanity cabinet c/w frosted glass doors for WC 1 (L2ft) $280
Electrical works
To supply labour, tools, materials to run the following electrical points:
1) 8 lights points $280
2) 3 heater points $300
3) 3 double socket $210
4) 1 single socket $50
Miscellaneous
To supply labour, tools, materials to:
1) undercoat oil base sealer to 3 bathrooms ceiling & gypsum board partitions $150
2) install 10mm thick clear tempered glas shower screen WC2 $480
3) install wrought rion main gate (3ftx7ftt) $480
4) install solid nyatoh main door c/w pressed lock $450
5) install 3 sets of acrylic bi-fold doors for toilets $600
6) install 1 sets of acrylic sliding doors for storeroom $200
7) do haulage, removal, disposal of debris $200
8) do acid wash before hand over FOC
Total cost: $27,920
Demolition work
total $2600
Masonry Works
Partition work:
Plumbling
Carpentry works
Electrical works
Miscellaneous
Total cost: $27,920
I can do it for 27,500... If u want email to kidobuilders@gmail.com......and i provide 3 D for carpentary works... Cheers
I could be wrong but I think it is rare to charge for the above items. Mine came free. Maybe u try asking him to take do it FOC.
Hey I took a second look at ur quote. Is there going to be a kitchen work top? I dun see it in the quote. Pls also get him to include how much are the tiles psf so u know what type of tiles u can pick. for eg @$3 psf
No there wont be a kitchen work top. I ll be getting it directly from the supplier to install it. The tiles I can choose up to a maximum of $3.50psf. ID said he will refund me the excess if I choose a lower priced tile. Also for the kitchen cabinets, if actual measurement is less than quoted, he would also refund me the balance. Is this a fair deal?
Hi ...i think its slightly expensive ...( hopefully im not to late in giving my comments) why dont u go to some contractors where they got packages and then u can add on ... ( sumthing like Chew Interior/ -/ *) coz ...not much expertise needed on design aspects when renovating kitchen and toilets...
cheers
Hi Im also planning for a small reno for kitchen. Whats the charges for the Kitchen top per square foot run ( solid surface top ?? )? if you dont mind , Please help to share the contact of supplier for Kitchen top?
Demolition work
total $2600
Masonry Works
Partition work:
Plumbling
Carpentry works
Electrical works
Miscellaneous
Total cost: $27,920
Can you PM me your contractor contact? Thanks in advance.
