Jo77
My Renovation Quote. Pls Help To Advise.
Hi folks,
Need advise on whether the following quote is too expensive. I do feel so, hence am asking for advise.
Wiring of the place is not yet included. Air-con not included as well
CARPENTRY WORK
Foyer
1) To supple deisgn install and fabricate full height shoe cabinet with selected laminated finishing - $1250
Living Area
2) To supply design, fabricate and install TV feature wall up to 6 Ft come with shelving console concept with ledge for diaplay, laminate frame design and box up with plaster board design - $2980
Dining Area
3) To supply deisgn, fabricate and install suspended altar cabinet come with drawer drawers in laminate finishing - $780
Kitchen Area
4) To supply fabricate and install kitchen kitchen bottom cabinets come with laminate and ABS trimming door -$1560
5) To supply labour and install solid surface work top at kitchen cabinet - $920
6) To supple fabricate and install full height cabinet and include boxed up sewage long pipe in selected laminate finishing - $480
Master Bedroom Area
7) To supply design, fabricate and install full hright sliding door wardrobe in selected laminate finishing - $2240
8) To supple design, fabricate and install suspended dressing table come with mirror and selected laminate finishing - $1000
9) To supply design, fabricate and install suspended TV ledge in selected laminate finishing (4ft) - $480
Bedroom 2 Area
10) To supply design, fabricate and install full height walk-in wardrobe with internal IPU design and selected laminate finishing - $2240
11) To supply design and install selected designed 'Supreme' platform in selected laminate finishing - $750
12) To supply labour and material to install fell height mirror - $680
13) To supply design, fabricate and install suspended ledge in selected laminated finishing (2ft) - $150
14) To supply design, fabricate and install low height study table come with 1 drawer in selected laminate finishing - $720
15) To supply design, fabricate and install helf height laminate headboard come with selected laminate finishing - $510
16) To supply design, fabricate and install suspended TV ledge in selected laminate finishing (5ft) - $600
Bedroom 3 Area
17) To supply design, fabricate and install full height cabinet comes with drawers, glass swing doors, internal laminate design in selected laminate finishing - $4950
HACKING WORK
18) To supply labour to dismantle exisiting false ceiling and simple cornices for whole house - $500
Kitchen Area
19) To supply labour and equipment to hack wall tiles - $900
20) To supply labour and equipment to hack hollow balock wall between kitchen and dining area - $90
21) To supply labour to dismantle existing kitchen cabinet - $280
22) To supply labour to dismantle existing sink and stove support - $ 180
Bedroom 2
23) To supply labour and equipment to hack hollow walls between bedroom 2 and store area - $180
24) To supply labour to dismantle existing skirting - $80
Store Area
25) To supply labour to dismantle existing door and door frames - $70
Bedroom 3
26) To supply labour to dismantle existing cabinet - $180
WET WORK
Kitchen Area
27) To supply and construct 'L-shape' Kitchen cabinet base - $380
28) To supply and construct fridge base - $110
29) To supply and construct washing machine base - $110
30) To supply material and overlay homogenous floor tiles with selected floor tiles finish (only $3 per sq ft) - $1500
31) To supply material and overlay homogenous wall tiles woth selected tiles finish (Only $3 per sq ft) - $2970
Store Area
32) To supply and seal door size entrance with hollow block and plaster smooth finish - $380
LAMINATE FLOORING
33) To supply and lay selected deisnged ' Supreme' Laminate Flooring for Bedroom 2 Area (170 Sq Ft) - $1020
PLUMBING WORK
34) To supply labour and materials to run stainless steel inlet piping, run PVC outlet piping (excludes Tap and sink) - $580
PAINTING WORK
35) To supply labour to paint all interior walls and ceiling using Nippon Vinilex 5000 - $1550
WOODEN DOOR WORK
36) To supply labour and materials to install designer room doors with standard lock (x3) and to install beading design at door frame both size - $1410
GLASS WORK
37) To supply Labour and materials to install 10mm tempered fixed clear glass at walk-in wardrobe area - $600
CEILING WORK
38) To supply labour and material to construct false ceiling at foyer, bedroom's corridor and to construct L-box **** and dining area - $2850
MISCELLENOUS
39) To provide general cleaning, acid washing for whole house - $ 1400
TOTAL COST = $43211.95 with GST.
Hi folks,
CARPENTRY WORK
Foyer
Living Area
Dining Area
Kitchen Area
Master Bedroom Area
Bedroom 2 Area
Bedroom 3 Area
HACKING WORK
Kitchen Area
Bedroom 2
Store Area
Bedroom 3
WET WORK
Kitchen Area
Store Area
LAMINATE FLOORING
PLUMBING WORK
PAINTING WORK
WOODEN DOOR WORK
GLASS WORK
CEILING WORK
MISCELLENOUS
Hi bro, your carpentry work look ex but if u using high end lamination and complex design than i don knw how much liao. your kitchen top 11.5ft huh?
your hacking & dismantle look a little ex, also your kitchen floor area got 190sft? and your wall area at350sft? What wooden door you using huh ? 470 with beads design your beads how much huh?
your ceiling how many sft for lower ceiling and L-box? you staying in which type of flat? why general cleaning and acid wash for whole house so EX 1?
think u need to compare quote from others.
Cheers.
Edited by Ark7
Hi folks,
CARPENTRY WORK
Foyer
Living Area
Dining Area
Kitchen Area
Master Bedroom Area
Bedroom 2 Area
Bedroom 3 Area
HACKING WORK
Kitchen Area
Bedroom 2
Store Area
Bedroom 3
WET WORK
Kitchen Area
Store Area
LAMINATE FLOORING
PLUMBING WORK
PAINTING WORK
WOODEN DOOR WORK
GLASS WORK
CEILING WORK
MISCELLENOUS
Hi ... i am contractor myself .. Based on the quote u have ....is a bit on the high side of things...
.. First of all is .Have the designer show u the 3d picture and is it what u want ..Its not use trying to check whether price is expensive if what quoted is not what u wish for ...
For the carpentary work can u put in the measurement than i can advise u .. cheers
