runmyhousehold
What To Do With Terrazo?
Our balcony has some super obiang terrazo tiles. Besides hacking and re-tiling, are there any other options? Any suggestions?
You could continue using them if you could design the house that matches with the tiles. If you want to restore the shine of your terrazzo, you can polish the tiles with a terrazzo grinder which is like a heavy floor polisher. After polishing, you can clean and seal the dry surface for a lustrous finish.
Cheers!
Cheers!
Unfortunately, it doesn't match at all! It's ghastly to say the least. But to hack and re-tile may be quite ex so I was looking for cheaper alternatives.
Another alternative is to lay outdoor bamboo/ chengai wood strips above your terrazzo. If that doesn't work, you can try overlay tiles or pebbles on your existing terrazzo.
Cheers!
Cheers!
Thanks so much!! Great ideas!
Cheers!
Balcony is for rainwater to soak, sunlight to bake, bamboo/chengi strips tai boleh tahan lah. Some more at $12/psf. Can't withstand the sight of terrazzo? Want cheapest ? Lay vinyl sheet. Sleeping on top, shiok! Mopping also easy! Take take rainwater goes into betwwen tiles & the layer on top hor.
Edited by bepgof
