eteo
Gas Pipe Damage During Hacking Wall Tiles
Hi friends,
The above happened to me during the hacking of wall tiles.
Although I am no contractor, I would have thought that they should have traced how the gas pipe runs in the wall from the outlet by manually removing the surface tile and plaster. Can anyone advise how this is usually done?
Thanks friends.
Inform Citigas ASAP
Gas pipe damage is very serious.
If there is a gas leak and your neigbour or nearby happen to light up a light.
BOOM
Mine leak last time. New house.
Cornice say, electrician, electrician say ask ID.
Ah, finally never use City gas, just the tank type :(
Tracing is tedious job, bubble test ? But must hack wall le.
Easier to add new pipe.
Hi, the gas was turned off before the hacking started.
But the holes in the gas pipe are obvious. It seems to me that they did not take the precaution of tracing the pipe manually as I described above.
Now I have extra cost to bear to look for a licensed gas contractor to relay the pipe.
What I would like to know is if this is normal practice to hack without tracing the pipe?
must trace before hack.
Had cases happen before.
Father bought a condo. When the contractor up the kitchen cabinet. They accidentally drill a small gas on the pipe.
No one know, as the pipe is hide behind.
Son come back, sleep in his room and never wake up.
After this incident. For condo, it is a must to provide DWG for the gas pipe location.
New HDB.. I don't know liao.
Thanks Therat. I also think should trace before hack.
Are there some practice guidelines I can show them?
The contractor is denying any fault saying that it is concealed.
I don't know.
May be you can check with HDB
I know for condo, you can get the DWG from the MC
For concealed pipes, indeed difficult to track. Most contractors I spoke to mentioned that pipes (including water pipes) is likely to have some damages during hacking. Most of the older properties do not have piping drawings. Not sure if drawings include in the pipings now.
