neubie
Relocating & Adding Of Scv Points
indication mark SCV on the box is it old SCV box? cos got 1 electrician told me it is old type? got picture to see new SCV box?
i need electrician to do network point using cat6 and relocate SCV
ok, so indeed they are upfront with disclaimer...
but if u were to inspect their splitters inside their box, most likely they give those cheap MIC "Regal" brand splitters with rather high-loss characteristics when the incoming signal is split into the TV and FM output.
as far as i know, received signal requirements for MOL is far stringent for cableTV. weak signal due to high-losses prevents stable data transmission, starhub is able to remotely measure the signal strength from the cable modem if a complaint is lodged due to intermittent BB connections
So I need to buy quality cables & splitters and pass to my contractor when rewiring...
Huh? meaning if I got someone to do rewiring for the whole house...
do I still need to buy and supply the cables? how much would that be?
