htng
Samsung Top Load Diamond Drum Washer
Just bought one and after installing, water could not drain out. Ask technician to come down and he mention washing machine base not flat. Weird thing is suggest to put 2 piece of tiles on the back of washing machine support
Is this the right way? Anyone can provide some info?
sorry I dun really know how to help but perhaps you could try seeing w naked eye or measure e base on 1 end vs e other end to see if it's really level. if true, means yr contractor din do a good job. :o
insist on a replacement set if the problem cannot be solved.
Wah! What is Diamond drum?!
Sorry, long time no see household appliances liao.
Replace this model with a panasonic inverter and problem solve. No need for me to explain further.
