dpbandi
Kitchen Renovation Quotation
Hi Please help to comment on the following quotation ? is this price ok for the Kitchen top solid surface ? Looks like the rate is same as the Granite ??
1.To supply & install solid surface kitchen work top for the existing L-shaped concrete ( 11.87 ft)
support (2060mmL + 1560mmL x600mmD x70mmDrop) $840.00
*Extended of kitchen cabinets:( 4.9ft)
2.To construct top kitchen cabinet with ABS trimmings doors in laminate finished
(1500mmLx300mmD) $550.00
3. To construct bottom kitchen cabinet with ABS trimmings doors in laminate finished (6.3 ft)
(1950mmLx600mmD) $715.00
Edited by dpbandi
That's around $70/pf rite? Same as mine. Granite's price is definitely much higher.
That's ard $112/pf? Mine is $106/pf plus soft-closing for casement doors.
If you want to have a successful renovation in your kitchen all you need to do is to follow all the quotation that give on you but if can't afford to buy the materials you need just provide the affordable one.
