executiveowner
Renovation Quote - Need Advice
Hi, guys.
Just want to get a feel of the price my ID quoted. The reno is for an executive apartment with size around 143 sq m.
1) To demolish whole unit floor & wall tiles.
2) To dismantle all existing wardrobes, kitchen cabinets, all doors & frames.
3) To dismantle all basin & w.c. including all piping.
4) To demolish wall & create opening between kitchen & living area.
5) To remove all cornices.
6) To hack wall & remove windows at balcony area.
7) To supply sand & all haulage work.
8) Clearance of debris to government dumping ground
9) To cement smooth all damage area. - $3700
1) To supply & lay 2’ x 2’ polished homogenous flooring c/w skirting ****/dining/store area. $ 4,800.00
2) To supply & lay chengai wood strip flooring at balcony area. $ 2,800.00
3) To supply & lay matt homogenous floor tiles at kitchen/ service balcony area. $ 1,950.00
4) To supply & lay matt homogenous floor tiles at 02 toilets. $ 700.00
5) To supply & lay ceramic wall tiles (full Ht) at 02 toilets area. $ 2,200.00
6) To supply & lay ceramic wall tiles (full Ht) at kitchen area (except cabinet area). $ 600.00
7) To supply 04 pcs.ceramic design wall tiles at kitchen area. $ 150.00
8) To supply & lay ceramic wall tiles (half Ht) at service balcony. $ 1,300.00
9) To construct 02 nos. kerb for both toilets. $ 150.00
10) To cement screed 04 nos. bedroom area. $ 720.00
11) To construct kitchen cabinet, fridge, washing machine base and kerb for washing area. $ 350.00
12) To supply & install mid Length strip teak parquet at 04 nos. bedroom area c/w skirting. $ 3,900.00
1) To erect false ceiling at bedroom passage area, 04 nos. wardrobe area &
master bedroom entrance area. $ 700.00
2) To erect light holder **** area. $ 1,180.00
3) To erect simple cornice at 04 nos. bedroom & dining area. $ 1,500.00
4) To erect 1500mm full Ht partition wall at entrance area. $ 600.00
1) To supply & install sliding window grilles for whole unit except balcony area. $ 1,100.00
2) To supply & install toilet louver for 02 nos. toilet. $ 400.00
3) To supply and install 5100mm galvanized wrought iron grilles for balcony area. $ 1,650.00 ( shld be ard $1500 )
1) Painting for whole unit using ‘ICI DULUX PENTALITE’ or ‘NIPPON VINELEX 5000’ emulsion paint.
a) Wall and Ceiling.
b) Painting for all piping.
c) Painting for doors and doorframes. $ 1,700.00 (ard $1500)
2) To supply & install 02 nos. Auscreen tempered glass framed shower screen at 02 toilets. $ 1,160.00
3) To supply & install 02 nos. of ‘Besglas’ bi-fold door for 02 toilets.(safety glass) $ 1,100.00
1) To change existing piping to stainless steel piping for whole unit $ 750.00
2) Running / Connection of piping works. (Sink / Basin / Washing Point /Washing Machine). $ 320.00
3) To run & connect 05 nos. hot water points. $ 500.00
4) To supply labour to install 01 no. of gallon heater. (Items Not Included). Free
5) To supply labour to install toilet accessories. (Items Not Included). Free
6) To supply labour to fix 02 nos. w.c. & 02 nos. basin. (Items Not Included). $ 350.00
1) To construct a L2800mm x Ht2100mm solid Nyatoh sliding door c/w clear glass panel.(Balcony) $ 2,400.00
2) To construct a L2100mm x Ht2100mm solid Nyatoh sliding door c/w clear glass panel.(Balcony) $ 1,800.00
3) To construct a L1500mm x Ht2100mm solid Nyatoh sliding door c/w clear glass panel.(Study) $ 1,300.00
4) To supply & install 03 nos. of veneer ply doors c/w lever type lock. $ 1,140.00
5) To supply & install a L3ft x Ht7ft veneer ply main door. (Fire rated) $ 1,400.00
1) To construct a L2100mm full Ht laminated wardrobe c/w ‘alumix’ sliding door frames. $ 1,850.00
2) To construct a L2000mm full Ht laminated wardrobe. c/w ‘alumix’ sliding door frames. $ 1,750.00
3) To construct a L2500mm laminated casement door cabinet for recess area without backing. $ 700.00
4) To construct a L2700mm laminated casement door cabinet for recess area without backing. $ 760.00
1) To construct a L2000mm full Ht laminated wardrobe. $ 1,750.00 (casement door $1250, sliding door $1365)
2) To construct a L1200mm design partition c/w dressing table and mirror. $ 1,100.00
3) To construct a L1800mm study table. (balcony area) $ 780.00
4) To construct a L1500mm laminated casement door cabinet for recess area without backing. $ 420.00
1) To construct 02 nos. of 3ft vanity cabinet c/w solid surface worktop for 02 toilets. $ 1,700.00 (3 ft vanity $300 x 2 = $600 3ft solid surface $225 x 2 $450)
1) To construct a L2000mm full ht laminated bookshelf c/w a L1100mm open shelving. $ 1,800.00
2) To construct a L3100mm study table. $ 1,430.00
1) To construct a L3300mm full Ht designed feature wall c/w TV console. $ 3,300.00
2) To construct a L3200mm x 2800mm frameless mirror feature wall. $ 2,400.00 ( black mirror $1400)
3) To construct a L3400mm solid nyatoh sliding doors for kitchen entrance. $ 4,200.00
1) To construct a set of laminated kitchen cabinet.
a) L5900mm low laminated cabinet
b) L4200mm top – hung laminated cabinet
c) A set of stainless steel dish drying rack
d) A set of cutlery tray. $ 3,800.00 ( shld be less then $3500)
2) To supply and install L5900mm granite worktop. $ 2,200.00
3) To supply and install L2000mm granite worktop for counter top. $ 720.00
4) To supply and install L4500mm color tempered glass w/ wood backing between kitchen cabinets. $ 1,100.00 ( Ard $800)
Total cost = 77,110.00. Are the items reasonable? It excludes the electrical wiring, air-cons, lighting, fans and even the toilet accessories.
If it is too ex, anyone can tell me which are the items? Thanks a mil!
Hi juz to share my view based on the passed 2 quoted for mi n my bro hse.
hope it does help.
Anyway i believe the quote u get is from an id firm, usually there's a bit diff in price between a contarctor and id firm.
If u do interested u can try to get a quote from my contractor.
Cheers!
hope it does help.
Cheers!
hum.....too ex...
