htng 1 Report post Posted June 29, 2010 Guys Is it difficult to put cables through the feature wall since it is a whole solid wood. Also how do we run the cables around? Like speaker cables and HDMI cables etc? Share this post Link to post Share on other sites
wolflet 1 Report post Posted June 29, 2010 from my understanding, they usually have a "drain" in the feature wall that stretches from the tv to the console. u can just drop the cables into the drain and pull it out from within the console. if u are going to mount ur speakers to the feature wall, i think the speaker cables have to be pre-installed before installation of feature wall. Share this post Link to post Share on other sites
wcseow 0 Report post Posted June 29, 2010 There will be "drains" and "outlets" for those cable. What I did is to tell them to have a strong string pulled thru and leave it there. I normally even leave it there after I have lay all those cables, just in case I need to change later........... Share this post Link to post Share on other sites
htng 1 Report post Posted June 29, 2010 There will be "drains" and "outlets" for those cable. What I did is to tell them to have a strong string pulled thru and leave it there. I normally even leave it there after I have lay all those cables, just in case I need to change later........... thanks everyone Share this post Link to post Share on other sites
