bearlyn2406
Our Den In Fernvale Vista!
Ya i was about to ask te same questions... the water outlet is at where? at the compressor area for MBR?
But the way your trunking runs.. its not so obvious and its look more like a frame. nice!! my one very jia lat..
i c ur a/c is from BT.. my frenz in punggol use them as is full of praise for them! although in RT they got bombard quite heavily.. i tink u r e 1st n onli 1 to say my trunking r nice. haha..
water outlet in MBR ah? u mean e water will drain to where ah? MBR's toilet floor trap ah. can drain at the compressor area de meh?? then everytime turn on ur a/c then dnstairs neighbours will tot it's raining ah..
Edited by bearlyn2406
eh, thru passage way to toilet lo, or u r referring to other parts? cos i tot generally all run e same way? :unsure:
i was referring to the drainage from fancoils to toilet. Because for ours, to drain at floor trap in mbr toilet, the water pipe need to make a big roundabout from the wall where it enters. Am I making sense?
hmm.. mayb u wan to visit my unit? :unsure:
More updates on my reno work..
Gas piping and kitchen cab base
Fridge base (sharp corners, but inform Ben and rectified few hrs later. Very efficient! :good: )
Extra worktop base
Shower kerb in MBR's toilet
Went for shopping @ jalan berseh in the afternoon, and bought quite a lot of stuffs, not bad.. bought the following~
sink and tap, storage water heater, toilet accessories, mirrors, hob and hood, dish rack.. wa, shag sia.. zz
bought almost all the stuffs at GR link. went to hoe kee before tat but only stay 10 mins cos from e moment we went in, seems like no 1 wants to serve us so we left. :bleah:
Finalise warbdrobe, shoe cabs and kitchen cabs laminates and colour of paint with ID, also have electrician to start work liao. so far so gd, hope everything progress smoothly! :D
wa piang, u anytime wanna come also can leh. next wk got van, can go up c c. haha..
woo hoo steady.. i wanna go steal idea... haha..
wan.. i can get my id to save some money den do more things.. hahaha..
swee, no pro. i'll mix the sand n toilet paper together, u sort it out urself ah. haha..
my wife got a very long wishlist leh. u wan sponsor me any of the items or not? :thumbs up:
hi Bearlyn
ok you got the same arrgt as me, but just want to check this. Noticed that your shower kerb is closed, so water flow supposed to drain into the floor trap inside shower screen right? We wanted to do this, but contractor highlighted that water will pond because flow of water will end on outside floortrap, ie the area between the 2 floor traps will pond because flow is blocked by the closed shower kerb, so he proposed a kerb with an opening. Did you notice that?
hi Bearlyn
after looking at ur blog, now i understand ur question le.. hmmm.. din really notice tis till i c the explanation with the picture. I gotta ask my ID abt tis le. Thanks for ur info!! :good:
