erwin123
Mr16 Led Bulbs
Can you recommend a shop that has a good selection of Osram / Philips LEDs for MR16 (gu3.5) replacement.
I notice from the websites that Osram, Philips LED MR16 replacements have different beam angles for different applications 60, 30, 25, 10 degrees angle.
Another question. If I am installing a completely new downlight in false ceiling, would you recommend buying an existing MR16 casing with transformer which is widely available and installing MR16 LEDs into them rather than buying a dedicated LED spotlight?
Hi..I think you mean GU5.3, this is the most common socket for MR16.
You can PM me on our available range of MR16 LED.
For a new downlight fitting, I would recommend a dedicated LED downlight with driver. It works better and is more reliable.
Cheers
