dexufto
We Live Love Laugh
bro, ask for a full refund of the expedit shelves. insist on cash refund, not credit refund nor vouchers.
thanks for the advice bro,
Refund not possible.
Have already passed the 100 days policy.
(not like I can salvage by gluing it back)
:curse:
Hi Dexufto
I m interested in the downlights you used in your bedroom. Do you think 3W LED is bright enough? How many watts in your ceiling fan light?
Regards,
ncsl999
Sorry peeks,
something held up within the family..
PM sent.
<!--quoteo(post=596112:date=Dec 13 2010, 02:19 AM:name=laternel)--><div class='quotetop'>QUOTE (laternel @ Dec 13 2010, 02:19 AM) <a href="index.php?act=findpost&pid=596112"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->Hi there,
I saw your hse done up with laminated flooring(correct me if I am wrong), I would likt to ask how much did it cost you on the flooring for laminated wood. Need advise becuase I intend to do up my 3 bedrooms.<!--QuoteEnd--></div><!--QuoteEEnd-->
Hi edward, the renovation is almost completed;
left with the pole-system for my WIW and another final round of painting.
will do the pre/post pics when time allows..
<!--quoteo(post=596346:date=Dec 14 2010, 12:03 AM:name=edward)--><div class='quotetop'>QUOTE (edward @ Dec 14 2010, 12:03 AM) <a href="index.php?act=findpost&pid=596346"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->dex, is yr reno completed? are you going to show some before and after photos later on?<!--QuoteEnd--></div><!--QuoteEEnd-->
oic chang2,
that sounds do-able definitely,
All the best with your reno journey. hope that Edmund gives you a satisfactory quote..
<!--quoteo(post=596735:date=Dec 15 2010, 11:15 AM:name=chang2)--><div class='quotetop'>QUOTE (chang2 @ Dec 15 2010, 11:15 AM) <a href="index.php?act=findpost&pid=596735"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->Thank u dexufto for the contact, i'm not going to do any flooring..just cove light, feature wall, kitchen n 2 partition..hope can squeeze into my budget<!--QuoteEnd--></div><!--QuoteEEnd-->
Hi kenlim_76,
Prices and details are already documented at my earlier post here;
under the lights story.
<a href="http://www.renotalk.com/forum/index.php?s=&showtopic=31653&view=findpost&p=589972" target="_blank">http://www.renotalk.com/forum/index.php?s=...st&p=589972</a>
Didn't get it from online, got it from JB, 3Ws LED. Online maybe cheaper I heard.
<!--quoteo(post=596736:date=Dec 15 2010, 11:25 AM:name=kenlim_76)--><div class='quotetop'>QUOTE (kenlim_76 @ Dec 15 2010, 11:25 AM) <a href="index.php?act=findpost&pid=596736"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->you bought the led downlights from? how much each? thinking of buying online. How many watts are you using? 9w or 3w? appreciate your reply.<!--QuoteEnd--></div><!--QuoteEEnd-->
Hi macy84,
My main contractor is Edmund from A-decor,
It costs about $23k w/o the laminates, window grills+gates, false ceiling & my tv console.
Thee's some additionals/ subtractions during the renovation phase, will post up
Have sent you a PM. Sorry for the late reply.
<!--quoteo(post=596206:date=Dec 13 2010, 03:46 PM:name=macy84)--><div class='quotetop'>QUOTE (macy84 @ Dec 13 2010, 03:46 PM) <a href="index.php?act=findpost&pid=596206"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->Hi dexufto,
How much did u spend on the whole renovation and which contractor u engaged to?<!--QuoteEnd--></div><!--QuoteEEnd-->
<!--quoteo(post=596779:date=Dec 15 2010, 01:28 PM:name=macy84)--><div class='quotetop'>QUOTE (macy84 @ Dec 15 2010, 01:28 PM) <a href="index.php?act=findpost&pid=596779"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->hi there, how much u have spent for entire reno, include those lum sum accessories, wiring, plumping, everthing...
do you find ur contractor is good and responsive?
can u PM me ur reno details?
thanks<!--QuoteEnd--></div><!--QuoteEEnd-->
Hi dexufto,
How much does the extendable study table cost?
Thanks.
Regards,
ncsl999
during our stay, we got ourselves a study-table in the utility-room.
We wanted something that could fit our books and accomodate laptop/ printer
stuffs as well as a studying area.
Eventually Esther from Closetrobe provided us a solution;
The extended study area.
The extended study table was retracted back.
At the same time, the budget fitted a sliding door that we could use as a storage-room
hi ncs1999,
well, the downlights (located at the bedrest) for my mbr is for double-up as "bedside lamp". Frankly, the 2 3W-LED downlight is not enough if you wanna to illumate the whole bedroom.
As my earlier blog suggest, the LED downlight gives a narrow beam lighting (picture spotlight w/o heat) should you want to floodlights, go for the PLC downlights instead.
My bedroom fanlight is one Pair of 12W PLC E27 GE (said to give 700 lumens) bulb.
You wanna check the bulb holder that you are getting and you can mix & match accordingly.
For the Alpha V6 fan, it uses E27 bulbs, my living room uses a pair of 5W while bedroom a pair of 12W.
Hope I have answered your questions.
Speaking of which I have 4 x 40W E27 incandescent bulb to give away,
PM me if you are interested ;)
Hi Dexufto
Regards,
ncsl999
Edited by dexufto
Hi dexufto,
Thanks.
Regards,
ncsl999
The extendable study table costs $300 per feet, so it bills up to be $1350.
It is actually a modular system of which Closetrobe customise it to fit our
function; we wanted a this study-table at the same time, a storage space
in the utility room.
So they created an empty partition for my storage, the modular unit (meant to
be inside) was taken out to be the study-table.
I hope my explanation is clear.
Hence package includes false partiton for the sliding door+ study-table.
Call Esther to fit your requirements. Overall, we are pleased with her services :thumbs up:
Hi dexufto, can pm me your contractor or id?
hi Shadoface,
My main contractor is Edmund Goh from A-Decor.
Have PM the contact.
The study table that you have quoted in the picture is not done by him, but from
Closetrobe
cheers
30L Magnum ELJF water heater
Heavy duty steel tank with titanium enamel coating
1000,000 times impact testing for pressure protection
single welding line for the inner tank
energy saving polyurethane foam insulation
magnesium anode with ss core
10 year warranty
<img src="http://i988.photobucket.com/albums/af6/dexufto/HDB_reno/DSCN3163.jpg" border="0" class="linked-image" />
6002 <a href="http://www.aos-bathroom.com/6002MF.html?id=49" target="_blank">Water Closet</a>
<img src="http://i988.photobucket.com/albums/af6/dexufto/HDB_reno/DSCN3164.jpg" border="0" class="linked-image" />
Hi dexufto
Sorry to recall this after you post this for so long.
I am looking for a squarish 30L storage heater for my resale flat I just got, and your this heater looks good.
May I know if this heater is good? How much did you pay for this and which supplier? How does this heater compar with the Ariston, if you know?
Really appreciate if you could give me some feedback asap.
Thanks again.
Hello bettyhong77,
No need to be apologetic. On the contary pardon me for the late reply as
I don't visit this forum like last time. PM me should anyone have any quiries,
as it will trigger to my email.
I can't compare apple to apple with Ariston as this is my 1st and only storage
heater I ever own and use now. Nevertheless, I read reviews that Ariston from
one of the thread that the heat retention is not good.
I've shared that I ever powered up my heater and the water is still hot the
following day.
I purchased all my bath stuffs from AOS building materials,
good customer service I must say.
Look for Mr Sunny.
Goodluck.
Hi dexufto
Thanks again.
Hi dexufto
Thanks for your reply. I tried PM yo le, but not successful.
Anyway, I tried search AOS building material, but not sure. If you still have, can give me the address and contact number?
Thanks again.
Hi dexufto,
Thanks for sharing your experience.
I am also considering getting my bathroom sanitary wares from AOS. Care to share your experiences with their W.C.s and basins? I am getting 2x Model #6002, and 1x Model #1030, along with their water heaters.
FYI, bettyhong77, AOS address is 178, Paya Lebar Rd #05-10 (Next to Traffic Police HQ), Tel: 6842 0030.
Thanks!
Hi dexufto
Thanks again.
Hi dexufto,
Thanks!
Yup, m100ky's address is correct.
I was earlier eyeing on Baron's W.C, however AOS have some package deals and got the Magnum 6002 instead.
The W.C function as expected, even the half-flush is effective for 'big business'.
one thing i learnt from the forum that You shouldn't pick those little ticks for W.C.
The slow-closing feature for the toilet seat has failed already though, almost coming to 2yrs of use.
Have previously shared about Magnum water heater. Fantastic.
takes some 5-10mins to heat up the 30L heater.
I believe i have previously reviewed AOS.
One lasting impression is their customer service.
I've previously ordered a A.O Smith cylindrical heater, turn out it couldn't fit my bathroom, I had them
brought back the heater and so I downsize to a 15Litre. After some consultation, i changed my mind and
they recommended me to this current squarish Magnum heater.
On a similar note, i had the mirror cabinet changed as well due to some blemishes.
No questions asked.
Quite a fussy customer am I? any more questions? ;P
I've gotten a Queen-sized KingKoil Rosedale Rosedale with 1.5" latex topper with Storage divan+ leather headrest for $2050 during the Kingkoil sale at Matu****a.
<img src="http://i988.photobucket.com/albums/af6/dexufto/HDB_reno/DSCN3354.jpg" border="0" class="linked-image" />
<img src="http://i988.photobucket.com/albums/af6/dexufto/HDB_reno/DSCN3353.jpg" border="0" class="linked-image" />
Mattress shopping can be quite tricky, Robinsons, mattress company would normally flood the newspaper with sales advertisement over the weekend, and tell you that this promo is vaild on till <b>this</b> Sunday.
Don't buy their crap, walk away if they try to hard-sell.
Ask for free pillows/ bolsters/ mattress-protector. The sales man can usually give to you free.
Do remember to bring along your partner for the mattress shopping; lie on the bed, toss around for 5-10mins.
Was told by one of the sales person Side-sleepers should go for a softer bed, i.e with better comfort-layers.
<i>(note especially if you are buying odd-size beds/ mattress; ie european size/ US size, as the regular bedsheet/ mattress protector/ bed frames may not fit)</i>
<a href="http://www.sleeppost.com/index.php?PHPSESSID=fa7d579ba7751b00a76e54199907b8b1" target="_blank">Sleeppost</a> and <a href="http://www.ibeds.com.sg/" target="_blank">ibeds</a> are nice website to start with.
hope this helps. <img src="http://www.renotalk.com/forum/public/style_emoticons/<#EMO_DIR#>/rolleyes.gif" style="vertical-align:middle" emoid=":rolleyes:" border="0" alt="rolleyes.gif" />
Last but not least, we have decided something to remnd ourselves before the bed;
<img src="http://i988.photobucket.com/albums/af6/dexufto/HDB_reno/DSCN3356.jpg" border="0" class="linked-image" />
Hi Dexufto,
Sorry but may i know where do you actually got that 1st Corinthian 13:4-8 wall decal? Mind sharing with me? Your PM is full..
hi Shadoface,
Closetrobe
cheers
Hi Dexufto,
Can you share your contractor contact? He is a contractor or ID?
Im looking one for my house...
TIA!!
