yuene 0 Report post Posted June 25, 2010 Welcome to RT! Here's wishing you a smooth renovation! Marsiling... hmmm I used to live in that area. Which part are you at? Share this post Link to post Share on other sites
cath76 0 Report post Posted July 1, 2010 (edited) Hi all, The tiling works have begun on 28/6 and there's been much progress so far. *First of two posts.* Some of the kitchen wall tiles are up and E says the glossy white tiles look great except... they've been laid vertically instead of horizontally, different from what E communicated with Jeremy (DeFong). E says that Jeremy would get that sorted out in due time. The toilet wall tiles went up on 29/6 as you can see but... E noted that the tiles cut to fit the corners had uneven dimensions, with the edges differing by 1-2mm between each tile. The combined photos show the uneven dimensions more clearly. Uneven tiles also spotted above the toilet window as well... E called up Jeremy about this and Jeremy said that he would take care of the matter as well. Edited July 1, 2010 by cath76 Share this post Link to post Share on other sites
cath76 0 Report post Posted July 1, 2010 (edited) *Second of two posts.* Anyway, they started waterproofing both toilets on 30/6 One wall of tiles in the master bedroom has also been put up and like E said, the tiles with the marble-like finish look very classy. However, E said that cut tiles with uneven dimensions were present again and this time, the variances seemed like 3-4mm. (E couldn't measure the dimensions as the waterproofing was still wet.) Another combined picture showing the the uneven dimensions of the cut tiles. I'm wondering if such uneven lines are normal or acceptable? (I hope I'm not overreacting.) Right now, I can't help but feel concerned about the workmanship. Feeling quite helpless too as E tackles the reno alone while I'm overseas. E says things will work out ok and to give Jeremy/DeFong some more time to settle the issue. Edited July 1, 2010 by cath76 Share this post Link to post Share on other sites
lilithfiend 0 Report post Posted July 2, 2010 wow the uneven tiles are quite obvious in the MBR toilet..i wouldn't accept this if i were u.. Share this post Link to post Share on other sites
davidbslee 1 Report post Posted July 2, 2010 (edited) I was like you before. Everything will also call the ID about it. But I learn to accept it as things cannot be 100% perfect when come to tiles and somemore ours is resale flat. Hope to see yr reno complete soon. Thanks for sharing. Edited July 2, 2010 by davidbslee Share this post Link to post Share on other sites
d'lotus 0 Report post Posted July 2, 2010 I was like you before. Everything will also call the ID about it. But I learn to accept it as things cannot be 100% perfect when come to tiles and somemore ours is resale flat. Hope to see yr reno complete soon. Thanks for sharing. Actually, the cutting of the tiles is due to workmanship - nothing to do with whether it's a resale flat or otherwise. Hopefully the lines will not be so visible after grouting. Cheers Share this post Link to post Share on other sites
cath76 0 Report post Posted July 2, 2010 Wow, I'm so heartened by the replies from fellow forumers. Kind of in two minds about the situation... POSITIVE E noticed that some portions of the wall were slightly uneven. Maybe like what d'lotus says, the completed grouting will make things look better. We also understand that some variations are unavoidable (agree with davidbslee, we can't expect absolute perfection when we are not perfect ourselves). NEGATIVE E said that the rest of the normal (i.e. uncut) tiles were laid out quite neatly, so that could point to problems with measuring & cutting of the tiles. Although variations are unavoidable, they shouldn't be *that* obvious. As it is, I can only wait for more situation reports & pictures from E. Poor E's tied up with course now & still making a point to visit the flat every day. Fingers crossed for things to work out smoothly. Share this post Link to post Share on other sites
curryqueen 0 Report post Posted July 2, 2010 I just realized that the previous owners were extremely innovative! Used a bamboo pole & raffia string as a kitchen rod! Serves the same purpose as a stainless steel rod & won't tarnish.. Share this post Link to post Share on other sites
cath76 0 Report post Posted July 3, 2010 Welcome to RT! Here's wishing you a smooth renovation! Marsiling... hmmm I used to live in that area. Which part are you at? Our unit's just a few blocks behind the MRT station; we think the location's great. I just realized that the previous owners were extremely innovative! Used a bamboo pole & raffia string as a kitchen rod! Serves the same purpose as a stainless steel rod & won't tarnish.. Wow, I didn't notice that detail before. Cheap and effective. Share this post Link to post Share on other sites
cath76 0 Report post Posted July 3, 2010 Twelfth day in and I'm feeling so much more relieved with E's good news. The kitchen's still the main staging area. The wall of tiles that were initially installed wrongly have been fixed; it lengthens the look of the kitchen. More progress in the toilet with all four walls tiled from floor to ceiling. Jeremy (DeFong) has come through. The corners seemed to have been reworked and are definitely neater now. E sampled nine joints and they look ok. They should look even better when the grouting is done. The tiles above the toilet window have been redone too. Again, nothing glaring or out-of-line this time. Share this post Link to post Share on other sites
cath76 0 Report post Posted July 3, 2010 All four walls in the master bedroom toilet have been tiled too; can't wait to see the "marble" tiles in person. E's sampled the wall joints here too and they look ok. The master bedroom toilet floor's mostly done too. E said that the original floor tiles were supposed to be a darker shade of grey but the supplier was out of stock till late July. I think the lighter shade works well. The right side of the toilet was also slightly raised to form a shower space on the left; we plan to have a shower screen installed. E noticed a flaw there though (where the red arrow points to)... The chip on the floor tile & the gap in the wall tile look quite bad. E also said that the steps leading up to the unit suffered a chip too. Two issues more to resolve no doubt but after this week, I think we don't have to worry ourselves silly for now. Share this post Link to post Share on other sites
berry_surprise 0 Report post Posted July 4, 2010 sorry to add but the tiling is bad. Share this post Link to post Share on other sites
dexufto 5 Report post Posted July 4, 2010 sorry to add but the tiling is bad. Hi, greetings from a fellow 3-roomer. You toilet looks big and spacious Hopefully, your titling will look better after completion. Share this post Link to post Share on other sites
cath76 0 Report post Posted July 6, 2010 sorry to add but the tiling is bad.Do you mean the chipped front steps? They are original condition and we haven't decided if we'll have them replaced yet. As for the rest of the tiling works, we did have some concerns initially but it just took E one call to Jeremy (DeFong) and the tiles were rectified within the week. More credit to Jeremy for taking the initiative to fix the chipped MBR toilet floor tile without prompting from E. Hi, greetings from a fellow 3-roomer. You toilet looks big and spacious Hopefully, your titling will look better after completion. Thanks, dexufto! The tiling and grouting works are almost done and things are starting to look good. Both toilets are taking shape nicely... The next big items will be the sanitaryware, I suppose. The kitchen floor tiles and cabinet bases are also mostly in place. We chose large light grey ones to keep the kitchen looking spacious. E's picked up the kitchen sink and tap too. We've also just finalised our selection of kitchen laminates, solid surface colors and paint colours. I know it sure wasn't easy co-ordinating our choices while I'm overseas; changed my selections at least three times before E put his foot down. *Sorry for driving you up the wall with my indicisiveness, dear* E says that the lights are due to be up by the week too. Looking forward to more exciting developments... Share this post Link to post Share on other sites
cath76 0 Report post Posted July 8, 2010 The tiling works are all done for both toilet and the kitchen while the electrical work has started. The new light for the common toilet has yet to be installed but the area around the window has been finished off neatly. All the grouting is done too. We are now seeing the MBR toilet for the first time in white light (the original bulb was a filament bulb). The one wall in the kitchen designated for tiling is also complete while the other walls have been screeded. Such a difference from when we first saw the kitchen with the original tiles falling off. The new lights for the living room are also up. A fresh coat of paint will make a difference soon. The gas hob, sanitary ware and paints have also arrived. I think the next major item should be the kitchen cabinets. Once they are in, the whole look will start to take shape. Share this post Link to post Share on other sites
