Stone23
My Renovation Quotation
Hi folks,
Your advise is greatly appreciated.
Flat Type: 4A (104 sqm)
A: Demolish Work
1. Supply labour & tools to hack off existing floor tiles, wall tiles and clear debris ~$2,600
B: Living Room, 3 Bedrooms & Storage room
1. Supply & lay 600x600mm china homogenous tiles c/w skirting finish ~$4,300
2. Supply & install normal cornice to whole house c/w some false ceiling ~$950
3. Supply & install 1 no. of wrought iron gate ~$450
4. Supply & install 3 nos. of solid design doors to 3 bedroom~$840
5. Supply & install 1 no. of solid design main door ~$420
6. Supply & install full height laminated wardrobe in one of the common room c/w ABS trimming (5ft) ~$1,050
7. Supply & install full height laminated wardrobe in mater bedroom c/w ABS trimming (10ft) ~$2,100
8. Supply & install full height laminated partition c/w laminated sliding door in master bedroom ~$2,200
9. Supply & install laminated feature wall in the living area ~$1,380
10. Supply & install laminated TV console (6ft) ~$720
C: Kitchen
1. Supply & construct kitchen cabinet base ~$200
2. Supply labour & material to plaster wall ~$700
3. Supply & lay ceramic floor tiles ~$1,400
4. Supply & lay water proofing ~$200
5. Supply & install upper & lower laminated kitchen cabinet with ABS trimming finishing (20 ft by design) c/w laminated
laminated works top ~$2,400
6. Supply & construct kitchen sink support c/w tiles finish (6ft) ~$680
7. Supply & install 6mm red tempered glass in between up and down cabinet (8ft) ~$420
8. Supply & install wall tiles at window area and debris chute area ~$600
D: Two (2) toilets:
1. Supply labour to install 2 nos. of toilet bowl ~$200
2. Supply labour to install 2 nos. of basin ~$120
3. Supply & lay ceramic floor tiles ~$900
4. Supply & lay ceramic wall tiles up to ceiling height ~$2,800
5. Supply water proofing ~$300
6. Supply & install 1 no. of aluminum bi-fold door in common toilet ~$180
7. Supply labour & material to alter exisiting squat wc to siting wc ~$100
8. Supply labour & material to box up exisiting sewage pipe ~$600
E: Others:
1. Painting of whole house using ICI paints c/w oil best coated ~$1,250
2. Supply & install stainless steel pipe for the whole house (hot & cold) ~$950
3. Supply & install sliding aluminum window to all window ~$2,200
4. Supply & install 2 no.s of alumium grills to all windows ~$1,280
5. Supply & install 1 no. of s/s debris chute ~$160
6. Rewire for the whole house including fixing of lights ~$2,800
7. Supply & install 1 to 3 air-con (normal Panasonic) ~$1,950
Total Costs: $39,400
Please advise.
Hi Stone23
Which reno company quoto u ? Which are the reno company u have get quoto so far ?
For the air-con u can call All Best for the prices
Hi folks,
A: Demolish Work
C: Kitchen
D: Two (2) toilets:
E: Others:
Please advise.
Hi Stone23
Hi ninja,
谢谢你!!!
Is there any kind souls who can help me to take a look at the renovation quotation.
Please help and advise.
Thank you in advance!!!!!
Hi
As for grilles, u can try up www.tayboontat.com
Advise you to have more quotation n compare the price & profile material
Hi
Hi davidquek76,
Thank you for your advise.
Agreed that I should seek for more quotations and compare the prices.
As this quotation is done by sis in law's close relative so I am not sure on the prices that the contractor has quoted me.
This is my first house so I am unsure of what to do.
No one to seek help thus seeking help from all fellow members here...
Hi davidquek76,
Ask for some quotes first, then compare the prices.
For me, i won't throw everything in to one contractor, but provider you must got time to handle it, cause sometime quite troublesome for arrangement. haha
Hi davidquek76,
Hi maybe u can show us ur floor plan. Will be much easy for the bro here to advise.
As for the wardrobe is it sliding door or casement door?
Please advise.
Hi..
saw yr electrical qoute..
did yr ID inform you on how many lighting point.. switches available..
for yr reference.. here's mine.. mine cost SGD2,800.00 too
Electrical Works:-
1. Wire whole house new light + door bell points. (28 nos) $980.00
2. Installation of whole house lighting. (28 nos) $280.00
3. Wire new 1x13A. (09 nos) $495.00
4. Wire 2x13A. (03 nos) $195.00
5. Wire 15A air-con point. (01 nos) $120.00
6. Wire heater points. (02 nos) $220.00
7. Wire oven points. (1 nos) $120.00
8. Wire hood & hob. (02 nos) $170.00
9. SCV TV (02 nos) $220.00
FREE Supply & install splash cover for washing machine. (FOC)
FREE Install dimmer control @ living feature wall
FREE MK brand designer switches
for The aircon.. we're given free + installation upon signing up of the reno package
Hi davidquek76,
Trying to ask for quotations over the weekend. Seem like its a peak period now, all IDs and contractors stated that they will reply me within 2 weeks. They have alots of projects on hand currently.
Thanks for your suggestion. But I dont tin I am able to do the co-ordinating job if to seek for few contractors on different jobs.
Attached is my floor plan....
Its a WIW. The sliding door is to serve as a partition or separator btw the MBR and WIW.
Please advise.
Hi..
Electrical Works:-
Hi sazeryn,
Thanks for sharing your electrical qoute. Really appreciated on that.
As for my electrical quote, its jus an estimated quote on the electricity.
No breakdown costs. No much discussion on this issue.
My contractor mentioned that he will need to view my house before he can provide me with actual qoute.
So $2800 is an estimated amount.
(Not sure will be more or lesser).
$2800 before viewing ? Did you give the specifications to the electrician ? eg number of power points, lighting points, fans etc
Hi sazeryn,
Never. Not even a single topic on electrical issue. So I am actually quite surprised how the contractor can quote me such amount.
Dont know how the contractor calculated!!! He never even ask me the nos. of power points, etc..
Thankfully there is such a forum for us to discuss such issues.
To be honest, I dont even know how the electrical breakdown costs is all about until I spend times reading through the forum.
Hi folks,
A: Demolish Work
C: Kitchen
D: Two (2) toilets:
E: Others:
Please advise.
I feel reasonable not expensive? May i know is quote from deisgn firm or contractor?
Mine is almost 30k but without build in wardrobe for 3 bedroom, fixture wall , tv console and whole house rewiring , aircon ,D8 & B7also.
