simplez
Water Repellent Coating Vs Waterproofing
Hi, can anyone share what is the difference between water repellent coating and waterproofing?
If I would to do cement plastering in the toilet which one is recommended?
Edited by simplez
you need the following:
1. Waterproofing coat below the cement screed (MAPEI LASTIC)
2. Cement Screed to contain water proofing mixture (i regret not knowing about this).
3. One more on top to make it shine... you have two choices. One is acrylic coat and the other one is concrete hardener type where it gets absorbed into the concrete...
i bump into a fanstastic product called GECKO SUPER HARD but i can't find it in Singapore! :(
Water repellent coating means water still get chance to "attact" the medium after the coating. Waterproofing is 100% no water passage, but look out for those "gaps" & "edges" while applying such.
Cement screed with a layer of enamel paint = water repellent, excellent.
Edited by bepgof
Hi, what is the color of the enamel paint? any idea where I can buy it?
