bishop
Help! My Reno Quotes, Pls Advice/rate
HI! I'm staying in a 5rm flat and we're going to reno it, Kitchen plus some additional areas in Living and Bedrm (shoe rack and wardrobe).
I'd already signed for the standard package for the Kitchen and 2 Bathroom ($14500, coz exculde tiles for kitchen wall). Am more concern about the additional items listed.
Pls help to go thru are the items quoted on the high side? Appreciate your reading. Tks a lot.
1. To do Plastering at existing kitchen tiles (4500mm x 2700mm) - $850 (should include painting also)
2. To do Plastering at Master and common bathrm ceiling - $200
3. To hack existing floor skirting ****/Dining/3 bedrm with patch up and make good - $560
4. Supply & install 4nos of hot point at master and common bathrm - $360
5. To paint Living /Dining / 3 bedrm ceiling and wall using Nippon paint - $1900
6. Supply & install basin vanity top at common bathrm with mirror - $830
Size: L1500mm x W400mm x H200mm (vanity top)
Size: L1000mm x H500mm (mirror)
7. Supply & install 1set 10mm thick frameless tempered shower screen c/w fix panel & casement swing door with handle at Master bathrm - $750
8. Supply & install vanity top with suspended vanity cabinet at master bath - $580
9. Supply & install 13amp double power point - 2nos, 13amp single power point - 3nos, lighting point - 2 nos, cooker fuse point - 1 nos - $500
10. To supply and construct a new store using gypsum board partition to received a new paint (L3900mm x H2700mm) - $630
11. To supply and install MDF tic-tac door in emulsion paint finished (store door) - $3080
12. Additional length kitchen cabinet L5280mm - $2520
13. Additional length for kitchen worktop L2490mm - $960
14. To supply & install 8mm thick color back glass at kitchen area (this item is between top and bottom cabinet) - $850
15. Additonal full height storage cabinet c/w pullout tray in selected laminate finished - $700
L700mm x D600mm x H2700mm
16. Additional top cabinet above fridge area - $780
L1600mm x D600mm x H700mm
17. Design and fabricate full height build-in casement wardrobe in selected laminate finish at master bedrm - $2030
L2100mm x D600mm x H2700mm
18. Supply & construct full height gypsum board partition with selected paint finished - $530
Size: L3160mm x D100mm x H2700mm
total - $18218
I'm still thinking whether to do laminated flooring or relay tiles for living and bedrm, or don't do anything to the floor coz laminated seems out of theme, while tiles seems on the much higher size.
Thanks for any feedback in advance.
Erm... I think some are expensive? Dunno the rest.
Eg. Mine paint whole house, pipes, gate, door, frames using nippon 6 col is abt $1250, shower screen also much lower. I think your casement cupboard v ex at $290 pfr. Normal should be ~$210 to $220??
me thinks the above are expensive. how come u spending $3k on a store door? :P
other stuff i never got a quote before so cannot comment. :)
5. To paint Living /Dining / 3 bedrm ceiling and wall using Nippon paint - $1900 i paint whole house at 1600 ICI paint
7. Supply & install 1set 10mm thick frameless tempered shower screen c/w fix panel & casement swing door with handle at Master bathrm - $750 this set will only cost at most 600 if i don't remember wrong 600 is for 12mm ( normal length are like 4ft x 7ft)
12. Additional length kitchen cabinet L5280mm - $2520 depends on the lamination u use but find the price for this pretty ex
13. Additional length for kitchen worktop L2490mm - $960 what material of worktop u using??
16. Additional top cabinet above fridge area - $780 Wah.......
total - $18218
for painting of whole house, does it make any price different if it's en empty house, versus a house with furniture?
if house with furniture most likely they will include protection fee bro.
Cheer;-)
