aaatop
Help! Diy Downlights... Baffled!
the 2 ends of the tubes r just a 2 pins. how do i know which pins are + and - ? do i take a pin from each end and connect it together to the "live" and the other 2 pins to the neutral?
wires? the tube holder should have some wires. just use the same diameter will be ok. they are not that current hungry and wires need not be thick.
but why did you get some LED lights. may not be cheaper but with the LED strips you can customise the length easily. huge power savings as well if you leave it on for long hours.
Doesn't matter... either side will do
