Cvv 0 Report post Posted May 16, 2010 (edited) Lol Edited August 11, 2023 by Cvv Old post Share this post Link to post Share on other sites
leechaorui 2 Report post Posted May 17, 2010 may i know u have any1 to recoomand me, althought i have tight budget i neeed a 265cm tall n 230cm long acros the floor +55cm width cupboard(all in 1 with book selves n wardrobe) so hope u cna give me contacts, i hope that it last long coz my room has coz my cupboard to grow fungus due to moist from de masterbedroom which i don't know y, so i diying tml tearin down my whole room so not tearing down needed just need a contractor fast to help me make the cupboard thanks ppl all help be appreciated, i've search online alot of interior don't do the wardobe they do only whole house, so m trapped, and i called a few contractors alot are error numbers meaning no longer in use, so far the only one that pickup the call is akron furnishing quoting 1.6k. so i hope u guys can really help me as i don't really know much about such stuff, and if they say solid wood meaning is ok? or? coz my room as mentioned got quite bad temperature, + i have a few guitars at home so home that the cupboard could worked You can try contacting Kelvin. He is recommended by some forumers and is an engineer by training. Hence, he has better technical knowledge on building wardrobe that is more durable. You can contact him at 98758882. Share this post Link to post Share on other sites
blossomflower 0 Report post Posted June 14, 2010 may i know u have any1 to recoomand me, althought i have tight budget i neeed a 265cm tall n 230cm long acros the floor +55cm width cupboard(all in 1 with book selves n wardrobe) so hope u cna give me contacts, i hope that it last long coz my room has coz my cupboard to grow fungus due to moist from de masterbedroom which i don't know y, so i diying tml tearin down my whole room so not tearing down needed just need a contractor fast to help me make the cupboard thanks ppl all help be appreciated, i've search online alot of interior don't do the wardobe they do only whole house, so m trapped, and i called a few contractors alot are error numbers meaning no longer in use, so far the only one that pickup the call is akron furnishing quoting 1.6k. so i hope u guys can really help me as i don't really know much about such stuff, and if they say solid wood meaning is ok? or? coz my room as mentioned got quite bad temperature, + i have a few guitars at home so home that the cupboard could worked try contact carpenter to help you Share this post Link to post Share on other sites
Amy Choon 1 Report post Posted June 15, 2010 have you settled the moisture issue from the master bedroom? if you haven't, then don't build the wardrobe first lor.. cos the same thing is going to happen again wor. Share this post Link to post Share on other sites
