scl8k
Is This Quote Expensive, Enough Details?
Hacking Works
Supply labour & tools to dismantle & dispose existing kitchen cabinet $280.00
Supply labour & tools to hack existing sink & stove support $200.00
Supply labour & tools to hack wall & floor tiles for kitchen $1,000.00
Masonary Works ( Base on up to $3psf tile )
Supply labour, tools & material to lay 300mm x 600mm wall tiles for kitchen ( Up to ceiling height $3,500.00
Supply labour, tools & material to lay 300mm x 600mm non-slip homogenous floor tile for kitchen $1,100.00
Supply labour, tools & material to lay water-proofing membrane ( non-string grout, 104 quick seal, water-proof cement & chemical cement ) for kitchen flooring $300.00
Supply labour, tools & material to construct sink & stove support with 63mm hollow block & tiles finish $980.00
Supply labour, tools & material to construct kitchen cabinet, fridge & washing machine base with tiles finish $300.00
Plumbing Works
Supply labour, tools & material to run stainless steel pipe for hall & kitchen ( Cold water pipe ) $500.00
Supply labour & tools to install kitchen sink & tap $50.00
Supply labour & tools to install washing machine tap (Inculde tap ) $20.00
Supply labour & tools to install 1no toilet bowl for common toilet $80.00
Supply labour & tools to install 1no instant heater for common toilet $50.00
Supply labour & tools to install 1no 2way tap for common toilet $20.00
Electrical Works
To run new casing for existing power point & switches for kitchen $300.00
To shift 1no 13amp x 2 double power point @ hall $35.00
To run 1no new 13amp x 2 double power point @ master bedroom $60.00
To run 1no new lighting point for bedroom 2 ( Bedhead area ) $35.00
To shift 1no ceiling light from room to room $12.00
Aluminium Works
Supply labour, tools & material to install window grille for hall & bedroom 3 (std) $800.00
Supply labour, tools & material to install casement door with acrylic panel for sink & stove support $450.00
Plastering Works
Supply labour, tools & material to plaster smooth whole house interior wall & ceiling $2,400.00
Wrought Iron Works
Supply labour, tools & material to install main gate ( 3ft x 7ft ) $480.00
Carpentry Works ( Kitchen )
Supply labour, tools & material to install 29ft kitchen cabinet with laminate finish & ABS trimming include: stainless steel dish rack , designer's handle, 1no frosted glass panel door, chest of drawer, cutlery tray $3,190.00
Supply labour, tools & material to install 8.5ft soild surface work-top kitchen cabinet $680
Miscellaneous Works
Supply labour, tools & material to paint whole house interior wall, ceiling, doors, door frames & pipe using ICI paint ( Max. 5 colour ) $1400
Supply labour, tools & material to paint sealer for whole interior wall & ceiling $350
Supply labour, tools & material to install stainless steel rubbish chute $200
Haulage & clear debris $350
Acid washing for kitchen & genaral washing for whole house F.O.C
To lay protection for existing flooring F.O.C
Supply & install system 3 non-inverter air-con include bracket ( Panasonic ) $2140
Sub-total $5,120.00
Total $21,262.00
7% GST $1,488.34
Grand Total $22,750.34
Hacking Works
Plumbing Works
Electrical Works
Aluminium Works
Plastering Works
Wrought Iron Works
Miscellaneous Works
Sub-total $5,120.00
Total $21,262.00
7% GST $1,488.34
Bro, think you can check with other ID/contractor to compare price also. i recently just completed my kitchen and master toilet and change new door maybe u wanna call him and compare price but i don't think he's the cheapers around but the workmanship are good and always keep work place clean. Can pm u the contact.
Cheers;-)
Hacking Works
Plumbing Works
Electrical Works
Aluminium Works
Plastering Works
Wrought Iron Works
Miscellaneous Works
Sub-total $5,120.00
Total $21,262.00
7% GST $1,488.34
I feel it is very reasonable apart from the 7% gst. Anyway, u need to check the reputation of ur ID/ contractor to be safe. Able to share who is this?
hi htng,
i've pm you the id company name. not sure about sharing the specific id on this forum till i've decided whom to go with. plan to start reno 1-june so watch out for my t-blog :) btw, do you know the difference between the 't-blog' and the 'blog' sections?
scl8k your house how many rm? i also want to do renovation for my 4 rm house. can give me the contractor phone number? and what is sub-total $5120 for? i do not understand.
Your quote looks reasonable.. Care to share the contact via pm? Thanks in advance..
khan, suspender,
you shoul have a pm with id info
khan,
it's 5-room hdb flat. i should clarify that the work scope is primarily to reno the whole kitchen, and other misc (paint the whole flat, some bathroom work, add window grilles, replace front door grille). ignore the sub-total 5120 (id had a subtotal for every page and i forgot to delete the line before posting) -- sorry for the confusion.
