kinggadget
Help Needed - Cement Screeded Walls- Caoting?
hi i am new to renovating does anyone know how to coat a cement screed wall? heard that cement is porous and will crack with time, does anyone know abotu coating ot staining the cement for colour purpose and to protect the cement from cracking?
thanks
king
thanks
king
Old technique.
- Gently hack wall till many small holes.
- Apply a layer of layer of cement mixed with fine sand.
- Before the layer dry, spread powder-form cement onto layer.
- The power will "eat" into the layer slowly. Quickly make flat the power layer.
Not too sure about the color, best to ask cement seller or those old ppl.
Edited by bepgof
I was thinking of doing plastering for my kitchen walls as well, to save costs and also coz we dun think tat we will cook that often.. Is it the same as cement screed? How to maintain? :unsure: Apologies to kinggadget for highjacking yr thread.. :o
Not doing tiling, can always applying enamal paint onto existing wall, stains easlier to be cleaned, by damp clother.
Cement screed needs skills, patience & time consuming, some more on verticle wall! When I was young, I was helping my elder brother until I wanted to cry. Cement powder attacked nake palm/hand/eye/noise too, glove makes palm less "feeling", "throwing/ spreading" the power toward wall become not even!........many tips
Plastering is slightly different from cement screed. Plastering appeared to be "softer" after drying & will peel off, pieces by pieces if the base treament (adhesive force not enought) not proper done onto wall.
Proper plastering is : hack many small holes on wall, spread water-clean away powder as well let wall moist, wait dry a bit, apply plaster and make flat, let dry (best >12 hr), sand, clean with damp cloth, wait dry, apply primer, wait dry, apply enamal paint. Make sure plaster applies only one layer. Or if to apply second layer, make sure making tiny holes on wall again....otherwise 2nd layer will peel off, pieces & pieces, easily, after some time.
Those 1-rm HDB old rental flats were done in this ways(tile half high, half enamel paint)
Edited by bepgof
Hmmmm, I just told me contractor I want to plaster on existing wall tiles (saving on hacking cost and time) and paint with Easy-Wash Nippon.
He said can.
But this thread seems to say must hack wall tiles before plastering.... :unsure:
He said can.
If the tiles you mentioned are those ceramics type, & if yr contractor just "plaster" over it, the plaster layer won't last. Unless he does some minor hacking to make surface uneven, then the adhesion force is strong enough.
Anyway, hole him responsible for any cracking/peeling off. Usually, if work no good, effect will surface within 3 months.
Edited by bepgof
Eh, I am a bit confused. Coz my kitchen's current condition is half tile and half bare (enamel paint, I guess). So any suggestions on how I can save costs if I don't wanna do tiling? :unsure:
May consider the following alternatives:
1. Maintain as it is, repaint the enamel paint.
2. Hack away the tiles, apply plastering, make flush the whole wall, then apply enamel paint
Note: Enamel paint is sensitive to heat, may consider pastering tiles/stainless steel plate near the stove, for easy cleaning after cooking for long term.
Edited by bepgof
Thanx bepgof for the alternatives! Will be gg with the 2nd alternative as we dun like the existing wall tiles. :) Your information was very helpful! :good:
I also need one! 1 ID actually quote me more exp than wall tiles to do for kitchen area as he claimed tat epoxy is v exp???
Many also against it though I said I knw abt the crack lines... Is it so diff to do???
