whiteoryx
Cracked Cement On Hdb Flat
Hi all,
I just went for my flat's 1st appt and was informed by HDB that there is a major issue with the flat that i am buying. My unit is on the 2nd floor and i have a neighbour living on the first floor below. The major issue is that there is a huge crack on the flooring of my unit and this crack can also be seen from the neighbour's unit below. The seller has informed us that during instances when they wash their flat, the water would seep thru and leaked to the unit below and have received complains from the owner as well. I believe this is what they call a structural damage and i strongly believe this should fall under HDB's responsibility as they are the ones that built the flat. Putting the blamming game aside, i would just like to know how can i go about to repair this? I'm afraid that i i do hack the flooring, the crack might get worse or even bigger affecting the unit below who has already informed us that they will sue us if they are very much affected. Have any of you guys experience this before? Please help.
Thank you in advance and Best Regards
Whiteoryx
you feedback to HDB, then HDB technical officer will contact you cos my ceiling cement also got huge crack. HDB will say it not their problem de.
