erickoh75 0 Report post Posted April 9, 2010 My main door handle and lockset is in bad condition, and it will cost in excess of $800 to replace such a mortise lockset. Any ideas on how to salvage? Share this post Link to post Share on other sites
yoongf 11 Report post Posted April 10, 2010 Looks like a Balwin lockset? If it's solid brass, then can use autosol cream and remove the tarnish. Actually, I find a bit of aging looks more mature. If it's plated, then no hope liao. Share this post Link to post Share on other sites
erickoh75 0 Report post Posted April 10, 2010 Thanks! It's a Marks lockset.. I must say it didnt age gracefully, all the little dots makes it look like skin disease :X I guess no harm trying with autosol/brasso to see if it helps, thanks! Share this post Link to post Share on other sites
chilla18 0 Report post Posted April 14, 2010 Yes brasso and autosol will do the job but you have to flex your muscle a lot to make it look good or you can use a handy polisher (dremel with a polish pad and cream) will make the job easier. Thanks! It's a Marks lockset.. I must say it didnt age gracefully, all the little dots makes it look like skin disease :X I guess no harm trying with autosol/brasso to see if it helps, thanks! Share this post Link to post Share on other sites
gladyslim 0 Report post Posted April 14, 2010 Both autosol and brasso do not work on plated finishing material to give a shinning surface. Brasso works on brass or bronze material where it do not have a layer of protective coat. If you use Brasso or autosol to polish your plated lockset without finishing it with a protective coat, your lockset rust faster. Share this post Link to post Share on other sites
