pomchatchat
Low Water Pressure, A Restriction?
recently moved into a terrace house. felt the water pressure is a tad on the low side. wanted my contractor to up it a little more, but he said there is some "govt" restriction on water flow per cubic per house. if exceed will get fine.
is that for real?? where can i read more about this weird ruling?
HDB sent a contractor to my flat yesterday after I called in regarding low water pressure.
The contractor checked and turn on 3 of my taps to let iwater run on the same time.
He said these speed is aceptable as recently HDB has installed something like damper to restrict water usage.
Terrace house = Private house?
Should have own break tank (contain water) and water booster system (pumps) for water usage..... ;)
Maybe get the service ppl to adjust the pressure switch. Hope this helps..
