Eurypylus 0 Report post Posted October 12, 2010 idealistic said: Need all of your expertise here. What are the things we have to look out for in rewiring and hidden cost involved? What is the purpose of PUB testing? Does it mean an electrician without EMA cert cannot apply for PUB test? What is the purpose of earth bonding? And how do we define as good or bad The prices ranges are too wide. Why are some electricians charging rocket sky prices when rewiring is a standard job. ps for asking so much questions. The wiring system, ring circuit or parallel circuit. Nowadays new hdb flat use ring circuit, but older flat may still have parallel circuit. While both works the same in operation, ring circuit allow you to have spruce(not sure if I spell this right) meaning you may tap another lighting point or power point more easily. Then due to that ring circuit will cost more cable to be used, price may be higher. The size of cable used 1.5mm for lighting, 2.5mm for power, 4mm for water heater.... these are standard cable size used, if not PUB will not approve it. Cable insulation... this is standard as well, as the PUB tester will come with his "mega tester" to check insulation. Cheap non BS standard with thin insulation may cause the insulation to melt when heavy load is used, and may cause fire. Share this post Link to post Share on other sites
Tech_wizard 1 Report post Posted October 13, 2010 Hope you guys dont mind if I share my views. Actually there is nothing wrong with comparing price, but when doing so the person may also want to take into consideration on the services provided usually if their service is not good why would people recommend them in the OPEN forum. As to say only young people do price comparsion is actually not correct, it is done in all ages. I think why some owners are getting prices from the recommended contractor from the forum is to get their main-con to match or reduce price mainly because they would the main-con to be responsible for the entire project. My advice to those who have this intention is to get a verbal quote from the forum vendors instead of making them go down all the way especially when you know you wont be awarding them the job. No wrong to get good prices to save your hard earned money but just be fair to others who put in time and effort for you. PS - No offence intended. Share this post Link to post Share on other sites
steveong 0 Report post Posted May 10, 2011 On 5/17/2010 at 6:38 PM, jaskel said: <!--quoteo(post=532382:date=May 17 2010, 11:46 PM:name=holeyman2000)--><div class='quotetop'>QUOTE (holeyman2000 @ May 17 2010, 11:46 PM) <a href="index.php?act=findpost&pid=532382"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->on a side note, how much just for air-con point?? Do I need 3 points for 3 bedrooms or just one will do? First time doing air-con point.. was told by some air-con sales-person that one point is 189.00 (contractor) + $$$ PUB inspection total would amount to some 300+.... Sure or not?? I was doubtful so I was hesitate to even buy the air-con from him.... Any pointers?<!--QuoteEnd--></div><!--QuoteEEnd-->$90~$120 not conceal. u only need 1 20amp air-con isolator point for all the units and use an electrician not contractor. If u want PUB inspection mean that u need to engage a LEW to do the wiring, diagram and submit the application to SP services for inspection date. 1st time free, if failed the inspection, the next time asking them to inspect will be charged a fee. Normally ask for inspection is for whole house re-wiring, but for a point only, yes u can ask for it.....if u think worth it.Hi,Is it a MUST to do PUB test for whole house re-wiring? Thks. Share this post Link to post Share on other sites
Jhwl 0 Report post Posted May 10, 2011 On 4/3/2010 at 6:08 PM, Phantom said: <!--quoteo(post=516674:date=Apr 4 2010, 01:57 AM:name=kyan007)--><div class='quotetop'>QUOTE (kyan007 @ Apr 4 2010, 01:57 AM) <a href="index.php?act=findpost&pid=516674"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->I will be rewiring whole house - 5 room HDB (Woodlands). Cost me $5600.- New DB box- New switches- 2 heater point.- 2 air con point.- Downlight 25 point.- 2 * Hanging Fan point.- 5 * SCV pointand power point....<!--QuoteEnd--></div><!--QuoteEEnd-->Gosh! Seems extremely pricey.Yea, It's very expensive. The total cost should be below $4000 Share this post Link to post Share on other sites
Jhwl 0 Report post Posted May 10, 2011 On 5/10/2011 at 8:21 AM, steveong said: Hi,Is it a MUST to do PUB test for whole house re-wiring? Thks.It's not a must. 100Amps above u need to engage a LEW. Each aircon point is 120$ or can be cheaper. Share this post Link to post Share on other sites
Faithful P 0 Report post Posted May 14, 2011 Hello gurusI'm quoted $2498 for the below items. Is it reasonable?($1998)Lighting point x 12Install light x 12 13A Single x 213A Double x 11Telephone point x1 Heater x 2SCV x 1Aircon plug x 1Circuit breaker($500)PUB testingSub-main cableBondingIs the PUB testing a must? Please help! Share this post Link to post Share on other sites
Celester 0 Report post Posted May 17, 2011 Can anyone advice is this quote expensive?I was quoted $5280/-Anyone have any good and reliable electrician to recommend?Install PLC downlight c/w lighting points x 22Install ceiling light c/w lighting points x 6Install wall fan/ pendant light c/w points x 2Install ceiling fan c/w light kits & lighting points x 4Supply & install lighting / wall fan point (only) x 3Install 3ft/4ft batten light c/w lighting points x 30Cutting & Hacking of ceiling for ceiling fan x 2Supply & install 13A (Single) S/8/0 points x 8Supply & install 13A (Double) S/8/0 points x 11Supply & install 15A air con S/8/0 points x 1Supply & install 20A parallel 2 way Heater points x 2Supply & install SCV cable points (Direct) x 4Supply & install SCV junction box c/w splitter x 1Supply & install Telephone Cable points x 4Supply & install 3 Core cable plug top point (Hood) x 1Install door bell c/w wiring points x 1Earthing system (Bonding) 6mm² CPC -6mm² sub-main cable (meter to DB Box) -Consumer Unit (DB Box) - Share this post Link to post Share on other sites
Faithful P 0 Report post Posted May 20, 2011 Hi CelesterAny per item cost? Share this post Link to post Share on other sites
Jhwl 0 Report post Posted May 26, 2011 On 5/17/2011 at 3:25 PM, Celester said: Can anyone advice is this quote expensive?I was quoted $5280/-Anyone have any good and reliable electrician to recommend?Install PLC downlight c/w lighting points x 22Install ceiling light c/w lighting points x 6Install wall fan/ pendant light c/w points x 2Install ceiling fan c/w light kits & lighting points x 4Supply & install lighting / wall fan point (only) x 3Install 3ft/4ft batten light c/w lighting points x 30Cutting & Hacking of ceiling for ceiling fan x 2Supply & install 13A (Single) S/8/0 points x 8Supply & install 13A (Double) S/8/0 points x 11Supply & install 15A air con S/8/0 points x 1Supply & install 20A parallel 2 way Heater points x 2Supply & install SCV cable points (Direct) x 4Supply & install SCV junction box c/w splitter x 1Supply & install Telephone Cable points x 4Supply & install 3 Core cable plug top point (Hood) x 1Install door bell c/w wiring points x 1Earthing system (Bonding) 6mm² CPC -6mm² sub-main cable (meter to DB Box) -Consumer Unit (DB Box) -Hi Celester you can try contact Mr.Yap 93960331 for quotes. Share this post Link to post Share on other sites
ricash 0 Report post Posted June 6, 2011 Some of rewiring quotations that I found on Renotalk.forum are from last year. This quotations are given to me by my ID recently. Please advise whether this quote is cheap or expensive.The quotations is quoted per point. Supply and labour Lighting Point $30Supply and labour Hanging Light Point With Installation $60Supply and labour 13A x 1 power point $50Supply and labour 13A x 2 power point $55Supply and labour SCV point $100Supply and labour Tel point $50Supply and labour 15A Air cond point $100Supply and labour Heater point $100Supply and labour Cooker Hood point $50Supply and labour Doorbell point ( with installation ) $40Supply and labour DB $350Installation of lighting $10HDB (NON-CONCEAL) Share this post Link to post Share on other sites
