jtcp82 0 Report post Posted April 1, 2010 Hi, I was advised by my contractor not to get system 4 aircon because if operating four units together, one unit will not be cold. Can any experts advise on whether this is true? Thanks in advance! Share this post Link to post Share on other sites
hcbing 0 Report post Posted April 1, 2010 I've heard the very same thing (generally) when I ask around some friends/colleagues who have installed system-4. Personally I think it's still dependent on the BTU volume choices for each units and of course of the compressor...but I believe this is quite true. Headache now... Share this post Link to post Share on other sites
GSXR~RACER 0 Report post Posted May 12, 2010 I have just installed system 4 two months back. Had quite a thorough search about price/pros n cons/brands/specs,e tc. basically many of the sys 4's in market are ~3HP units, means once u on all 4, its not as cold, or one rm is not cold depending on compressor type. But there are few (very few) options that has proper support for sys 4. In the reasonable price range, I chose mitsubishi Heavy Ind. It has 4HP inverter compressor 32k BTU and quite powerful for 4 std HDB bedrooms even when switched on all in the hot day. no difference if 1 only or 2 or 3 or 4 rooms on at the same time. And price is also not on the expensive side, plus the specs are good too. Around $3500 for sys 4. if u intending for 3 bedrooms+living room, then better to do sys3+sys1 two seperate aircons. Share this post Link to post Share on other sites
jtcp82 0 Report post Posted May 13, 2010 I have just installed system 4 two months back. Had quite a thorough search about price/pros n cons/brands/specs,e tc. basically many of the sys 4's in market are ~3HP units, means once u on all 4, its not as cold, or one rm is not cold depending on compressor type. But there are few (very few) options that has proper support for sys 4. In the reasonable price range, I chose mitsubishi Heavy Ind. It has 4HP inverter compressor 32k BTU and quite powerful for 4 std HDB bedrooms even when switched on all in the hot day. no difference if 1 only or 2 or 3 or 4 rooms on at the same time. And price is also not on the expensive side, plus the specs are good too. Around $3500 for sys 4. if u intending for 3 bedrooms+living room, then better to do sys3+sys1 two seperate aircons. Thanks GSXR~RACER. My contractor proposed Daikin, I will check with him whether it is 4HP. Share this post Link to post Share on other sites
wolflet 1 Report post Posted May 13, 2010 Thanks GSXR~RACER. My contractor proposed Daikin, I will check with him whether it is 4HP. from what i understand. daikin is not using the r410a gas which is supposedly more suitable for inverter aircon units. might wanna take that into consideration Share this post Link to post Share on other sites
jtcp82 0 Report post Posted May 13, 2010 from what i understand. daikin is not using the r410a gas which is supposedly more suitable for inverter aircon units. might wanna take that into consideration I though all new aircon model uses r410A refrigerant nowadays? Okay I will ask my contractor also. Thanks. Share this post Link to post Share on other sites
Devilaz 0 Report post Posted May 13, 2010 it depends on the compressor what BTU is it. Example: Compressor 34000 BTU Air-con : 9000 BTU each. If 4 air-con all on then will be 36000BTU exceed 2000 BTU. Still it will still able to cool down the entire area. But it takes a longer period of time. Not to forget if the owner is a heavy user, maintance of the air-con is required. Share this post Link to post Share on other sites
jtcp82 0 Report post Posted May 13, 2010 it depends on the compressor what BTU is it. Example: Compressor 34000 BTU Air-con : 9000 BTU each. If 4 air-con all on then will be 36000BTU exceed 2000 BTU. Still it will still able to cool down the entire area. But it takes a longer period of time. Not to forget if the owner is a heavy user, maintance of the air-con is required. I guess I wont switch on four aircons at the same time that often and most of the rooms only required around 8000BTU. Do you think I should buy system 3 plus one window unit for a the guest room? Thanks. Share this post Link to post Share on other sites
wolflet 1 Report post Posted May 13, 2010 I guess I wont switch on four aircons at the same time that often and most of the rooms only required around 8000BTU. Do you think I should buy system 3 plus one window unit for a the guest room? Thanks. for my 5rm flat, we intend to have a system 3 for the bedrooms and a system 1 for the living room Share this post Link to post Share on other sites
fabulous 0 Report post Posted May 14, 2010 Just to share. Recently I had purchased system 4 inverter aircon from Gain City. gone thru the process and had my fair share of headache. in the end my hb and I settled for the aircon with 9000 BTU for bedrooms and 18000 BTU for living room. Initially we intend to get system 3 + 1 type but as our flat does not have the aircon latch so we had to consider other option. My block does not have the higher electrical loading, in the end our selection of aircon is quite limited. You can check with your contractor. Share this post Link to post Share on other sites
spaceman 0 Report post Posted May 14, 2010 I have just installed system 4 two months back. Had quite a thorough search about price/pros n cons/brands/specs,e tc. basically many of the sys 4's in market are ~3HP units, means once u on all 4, its not as cold, or one rm is not cold depending on compressor type. But there are few (very few) options that has proper support for sys 4. In the reasonable price range, I chose mitsubishi Heavy Ind. It has 4HP inverter compressor 32k BTU and quite powerful for 4 std HDB bedrooms even when switched on all in the hot day. no difference if 1 only or 2 or 3 or 4 rooms on at the same time. And price is also not on the expensive side, plus the specs are good too. Around $3500 for sys 4. if u intending for 3 bedrooms+living room, then better to do sys3+sys1 two seperate aircons. Hi GXSR~RACER Is it convenient for you to share where did you get your aircon (system 4) from? Thanks. Share this post Link to post Share on other sites
Devilaz 0 Report post Posted May 17, 2010 I guess I wont switch on four aircons at the same time that often and most of the rooms only required around 8000BTU. Do you think I should buy system 3 plus one window unit for a the guest room? Thanks. well since you won't switch on all the 4 air-cons then would be good to get system 4. If you are getting a windown unit on it own, the consumption of electricity and the cost of the window unit will be more expensive. Sinces yours is 8000BTU in room then would be good to purchase system 4 inverter then. Also maintance wise they will count as system 4 rather then system 3 and 1 window unit. It will be more expensive. Hope you get what i mean. Share this post Link to post Share on other sites
jtcp82 0 Report post Posted May 17, 2010 Thanks for all your advise guys. I will go for the system 4 then. Share this post Link to post Share on other sites
bepgof 20 Report post Posted May 17, 2010 (edited) Thanks for all your advise guys. I will go for the system 4 then. In 1995, I've a system4, costed me almost 7K, also seldom turned on 4 FCUs at one time. What made me "regret" was "too many pipes" here & there. The "common drainage pipe" linked to all 4 FCUs then went to tiolet's floor trap. Wall opened holes here & there. 32A isolator switch. Think twice if you don't like so many pipes. Edited May 17, 2010 by bepgof Share this post Link to post Share on other sites
GSXR~RACER 0 Report post Posted May 17, 2010 Hi GXSR~RACER Is it convenient for you to share where did you get your aircon (system 4) from? Thanks. I took from Gain City, 3500-300cashback = 3200, and add $450 for stainless steel bracket. I didn't upgrade the pipings and warranty. the reason for that model is R410 inverter, can support 4 splits well, 4HP 32k BTU, and price. the reason for gain city is, they dun use the subcontractors. others like courts, harvey norman, blah blah etc are retailers for many things.. installation not done by their own staff. at least the installing technicians won't be saving on the material costs coz those all came from main company. Just my own reasons.. not necessarily right though.. Share this post Link to post Share on other sites
