libaocheng
Quotation From Id
Got a quotation from an ID. Anyone knows if the prices are fair? Please advise..
Demolition Works & General Services
To hack off existing wall between Master Bedroom & Bedroom2 as new entrance.
Haulage services
Disposal of renovation debris
Disposal of wood debris
Lump Sum
$500.00
Masonry Works
To supply materials & labour to construct H50mm cabinet base, side with tiles finish only. $300.00
To supply materials & labour to construct H50mm fridge base with tiles finish. $100.00
To supply materials & labour to construct H50mm washing machine base with tiles finish. $100.00
To supply materials & labour to touch up damages after hacking at Master Bedroom. $300.00
Plumbing Works
To supply materials & labour to extend existing copper pipe to new sink & washing machine area $350.00
To supply materials & labour to install concealed drainage pipe for new sink and washing machine. $150.00
To supply labour to install 2 nos instant heater at Master Bathroom & Common Bathroom. $100.00
To supply labour to install Kitchen sink & tap after carpentry work. $120.00
To supply labour to install Bathrooms' accessories. FOC
Aluminium / Wrought Iron / Glass Works
To supply materials & labour to install 10mm tempered frameless glass shower screen at Master Bathroom. $450.00
To supply materials & labour to install 10mm tempered frameless clear glass sliding door c/w handles, hinges & heavy duty top hung track finish at Kitchen. $900.00
Ceiling / Plasterboard / Partition Works
To supply materials & labour to install L-box light holder ****. $220.00
To supply materials & labour to install L-box light holder at Master Bedroom. $200.00
To supply materials & labour to install pelmet holder for Kitchen silding door pelmet. $150.00
To supply materials & labour to install light pelmet holder at Dining. $350.00
To supply materials & labour to install plasterboard false ceiling at Dining. $450.00
To supply materials & labour to install plasterboard false ceiling at Master Bedroom. $200.00
Miscellaneous
To supply materials & labour to paint whole house ceiling & wall using ICI emulsion paint. $1,400.00
To supply materials & labour to paint whole house gate, door, door frame, pipe & etc using ICI gloss paint. Inclusive
To supply materials & labour to lay cardboard protection at affected area / after flooring work $200.00
Acid washing for whole house to remove stains. $350.00
General Cleaning for whole house upon completion. Inclusive
Budgetary Carpentry Quotation
( Prices are subjected to change at final design & material stage )
Living/ Dining/ Household Shelther
Design, fabricate & install feature wall in laminate / veneer / mirror / glass / wall-covering in Living. $1,400.00
Size:L1800mm X H2100mm
Design, fabricate & install TV console in laminate, glass & white PVC carcass finish **** $900.00
Kitchen
Design, fabricate & install top & bottom kitchen cabinet with laminate & white PVC carcass finish c/w ABS trimmings, designer handles & cutlery tray. $4,900.00
To supply & install 13ft Solid-Surface Worktop $1,300.00
Master Bedroom
Design, fabricate & install walk-in-wardrobe in polyester finish at Master Room. $2,500.00
Size:L3300mm X Full Height
Design, fabricate & install Study Table c/w drawer unit in laminate & white PVC carcass finis $1,500.00
Design, fabricate & install book cabinet in laminate, white PVC carcass & glass finish. $2,000.00
Size:L2400mm X Full Height
Master Bathroom
To supply materials & labour to install solid surface top.
Design, fabricate & install suspended vanity cabinet in laminate finish.
To supply & install full size mirror at vanity area.
Lump Sum
850.00
Total: $22 240
Haulage services
Lump Sum
$500.00
Masonry Works
Plumbing Works
Miscellaneous
Kitchen
Master Bedroom
Master Bathroom
Lump Sum
850.00
Total: $22 240
I notice that this does not include Tiles am i right ?
Nope. No need tiles, HDB premium flat, so flooring already done.
Surprisingly i did nearly all the same stuff as you except that i have additional
-2m Study Table and Cabinets
-Tiling works for Hall & Rooms
-Tiling works for MBathroom Walls and Floor
-No Hacking New Flat-
However you have the additional Hacking of wall.
In Total my quote was just under 25K
So i dun think u are getting conned, but maybe on the medium high side.... but still cant be sure because it all comes down to the quality of the finished works and the customer service i guess.
For me i still yet to know as i just signed contract recently and only starting work in the next couple of weeks so will keep u updated as to the progress .... if turns out well maybe you may consider my guy as well .. heh heh .. :)
