renonewb
Please Help To Assess This Quote!
Hi there!
Very new to reno, so would be very appreciative if the reno experts here can comment on this quote? Thanks very much in advance!
1 Hack off existing 2 toilets wall & floor tiles $ 750.00
2 To supply & lay 2 toilets wall tiles up to ceiling height $ 1,980.00
3 To supply & lay 2 toilets flooring $ 780.00
4 To supply & install 2 no of frosted tempered glass doors at toilets $ 960.00
5 To supply labour to install 2 WC, basins & instant heaters $ 380.00
6 Hack off existing kitchen wall & floor tiles $ 750.00
7 To dismantle existing kitchen cabinet $ 250.00
8 To supply & lay cement screeding for kitchen wall $ 1,100.00
9 To supply & lay kitchen flooring $ 1,100.00
10 Waterproofing for kitchen & 2 toilets flooring $ 250.00
11 To construct cabinet base only $ 200.00
12 To supply & install laminated kitchen cabinet for 31 ft $ 3,100.00
13 To supply & install full height laminated storage cabinet estimated for 7.5 ft in kitchen $ 1,650.00
14 To supply & install solid surface top for 14 ft $ 910.00
15 To supply & install glass backing between top & bottom k/cabinet $ 820.00
16 To connect in/outlet piping for sink & washing machine $ 150.00
17 To supply & install stainless steel rubbish chute $ 180.00
18 To replace stainless steel piping at kitchen & 2 toilets $ 750.00
19 To construct low wall at kitchen come with tiling finish $ 360.00
20 Hack off existing wall at storeroom with patch up $ 280.00
21 To dismantle existing wardrobe & study table in 2 bedrooms $ 700.00
22 To dismantle existing skirting come with patch up at 3 bedrooms $ 450.00
23 Hack & relay homogenous flooring **** hall only $ 2,840.00
24 To supply & install laminate flooring c/w skirting at 3 bedrooms $ 2,070.00
25 To supply & install 1 set of wooden bi-fold doors $ 1,340.00
26 To supply & install 2 sets of laminated door at for room 2 & 3 $ 1,280.00
27 To supply & install veneer door at master bedroom $ 280.00
28 To supply & install laminated ledge for TV console estimated for 7 ft $ 700.00
29 To supply & install laminated settee with storage cabinet under living room window estimated for 8 ft $800.00
30 To supply & install white powder coated aluminium sliding window c/w green/blue glass for whole house $ 1,800.00
31 To supply & install white powder coated aluminium window grilles for whole house except 2 toilets $ 840.00
32 To supply & install white powder coated aluminium lorves window at 2 toilets $ 400.00
33 Wiring cost estimated for $ 1,200.00
34 To dismantle existing TV console cum display cabinet **** $ 250.00
35 To create new opening between master & bedroom 2 c/w patch up $ 280.00
36 To remove existing whole house simple cornice & false ceiling c/w patch up at 2 bedrooms $ 250.00
37 HDB permit fee $ FOC
38 Acid washing for whole house $ FOC
39 Haulage & debris disposal $ FOC
its better to indicate the size of your flat and your floor plan.
Some units have more window areas, so windows will cost more, etc. Bigger units = more stainless steel for piping, etc.
just curious, one set of wooden bi-fold costs $1340? sounds expensive to me.
Hi there!
Basically u can't compare reno quotes paple to apple, some "intangible" factors do matters like delivery timing, quality o/p, not-calculative, coordination between sub-con, etc. A "good" quotation should be clear & transparents with figures likes psf, tile price's range, etc otherwise the ID can easily "manipulate" the material, psf etc. Your quote seems lack this features, ask the ID to re-quote with details, see mine below (finalised after 3rd round of 4-eye meeting) and yet have some discrepancies with actual as built.(see yellow highlighted). My condo was done up by this id as well, 3 yrs ago.
http://img407.imageshack.us/img407/6179/te...efinalmarch.jpg
http://img215.imageshack.us/img215/6179/te...efinalmarch.jpg
http://img121.imageshack.us/img121/6179/te...efinalmarch.jpg
Edited by bepgof
hi gimz,
mine's a 4 room flat, 91sqm. thanks!
http://img144.imageshack.us/img144/6179/te...efinalmarch.jpg
http://img144.imageshack.us/img144/2593/te...finalmarchy.jpg
http://img532.imageshack.us/img532/6179/te...efinalmarch.jpg
hi bepgof,
thanks for your input! the quote was by a contractor so he said that's as detailed as he can get. had to check with him and note those down. i.e. the range for floor tiles were $3psf and those for walls were $2.40psf, laminate brands were power dekor and some others i haven't heard of etc. nice place you have there :)
