chow 0 Report post Posted March 4, 2010 Hi Guys / Gals I decide to setup lan points (cat6 cables), 2 points each at my living room and another 3 rooms However existing i have cornices in place, is it a hassle to setup? Do they need to hack the whole cornices to run the cables? Any good contractor for recommendation? Share this post Link to post Share on other sites
wolflet 1 Report post Posted March 8, 2010 Hi Guys / Gals I decide to setup lan points (cat6 cables), 2 points each at my living room and another 3 rooms However existing i have cornices in place, is it a hassle to setup? Do they need to hack the whole cornices to run the cables? Any good contractor for recommendation? if u want to hide the cables in the cornices.. then i guess have to redo the cornices. or u can just run the cables in trunkings. Share this post Link to post Share on other sites
Tech_wizard 1 Report post Posted September 27, 2010 Actually it would be more pratical to have Wifi instead of having LAN points, dont forget once the cables are laid and concealed in the event troubleshooting is requitred how are you going to remove or change the cable toms of headache and heatache. If you still want to have LAN points it is recommended you use cable brands like AMP. If you still need a contractor for cabling you can PM me for contact, I can give you the contact of my company contractor. Share this post Link to post Share on other sites
neubie 2 Report post Posted September 27, 2010 Hi Guys / Gals I decide to setup lan points (cat6 cables), 2 points each at my living room and another 3 rooms However existing i have cornices in place, is it a hassle to setup? Do they need to hack the whole cornices to run the cables? Any good contractor for recommendation? if you dun mind running half-inch trunking above the skirting, can DIY. very easy to do... Share this post Link to post Share on other sites
Eurypylus 0 Report post Posted September 27, 2010 Why not try drill a 1" hole in the cornice, then use the fiberglass leader to guide the cable from one end to the other, the patch the hole with plaster. Share this post Link to post Share on other sites
nightbug 0 Report post Posted May 22, 2011 Hi, I would also like to install 2 lan points for 2 rooms, 1 point per room, any contractor to recommend? Thanks! Share this post Link to post Share on other sites
navik 0 Report post Posted May 22, 2011 Hi also looking for contact to install lan points. Appreciate any help. Cheers Share this post Link to post Share on other sites
Spikey 0 Report post Posted May 22, 2011 me three - looking to install a LAN with Cat 6 cables. Share this post Link to post Share on other sites
wwz 0 Report post Posted July 1, 2011 hi guys, i just got my house rewired and also with cat 6 lan setup by my regular electrician. quite a good job done i must say. you can pm me for his contact. Share this post Link to post Share on other sites
destinyfate 0 Report post Posted July 26, 2011 (edited) anyone knows any qualified network people to to lay Cat 6 cables Edited July 26, 2011 by destinyfate Share this post Link to post Share on other sites
arowana 2 Report post Posted July 27, 2011 actualyl why not u guys use homeplug instead of laying lan cables? Connection is almost as good and hassle free. Share this post Link to post Share on other sites
neubie 2 Report post Posted July 27, 2011 actualyl why not u guys use homeplug instead of laying lan cables? Connection is almost as good and hassle free.connection quality is not as good as LAN cables, as the homeplugs is very susceptible to electrical noise. Share this post Link to post Share on other sites
ben263 0 Report post Posted August 22, 2011 my house is setup with all CAT 6 utp LAN points.but before we do that what is your backbone?if it's 10/100 why waste the CAT. 6 cable?CAT 5E will suffice or may I say over kill...Also if you lan points are coming out from a 10/100 base t router whats the point...Before setting up lan points, the most important thing to make sure of is the backbone cable.If you are using Opennet fair enough. But any other than opennet; backbone like RG59 or RJ11 cables are kind of time wasting.As what we call it copper will always be copper....My home setup:1. Backbone Opennet2. D-Link 8-port Gigabit Desktop switch X 2 (1000 Base T)3. D-Link Extreme N Gigabit router (1000 Base T)4. AMP NetConnect CAT 6 SL series 24port Patch Panel let me know if you need any help on networking Share this post Link to post Share on other sites
siongboon 0 Report post Posted August 23, 2011 Ya. I agree.CAT5e would be enough for 1000bps in our home.It is very easy to laid your own CAT cable.The cable, socket & the RJ45 crimper cost $100++.You can easily DIY, to save a lot of money.I have this website for your RJ45 color codehttp://siongboon.com/projects/2006-03-06_serial_communication/#Ethernet%20wiring Share this post Link to post Share on other sites
finkfad 0 Report post Posted September 4, 2011 Dear all,I'd like a contact for a contractor that does good CAT6 cabling. I have my own networking switches and all I need is for them to lay the cables + termination plates.Please PM me, appreciate it much! Share this post Link to post Share on other sites
