Better highlight to ur id, not to :fire: him but just to let him know if really cause by the workers then better rectify it. Cos u never know what will happen in future. Scali fall off?
Edited by gals_mama
Yesterday I went to my house and have a check, realised tiles, sand and cement all in the house liao. That's fast! Wednesday start hacking, by Sat 80% waste cleared and materials mostly are in.
I have an issue need some advice. I saw external wall damaged at my balcony area, it seems like affected upon removal of wall tiles in my balcony. In this case, what should I do? The crack is obvious and looks like half of the brick gonna to fall off but I try knock / pull the broken brick, it+doesn't+move.
got pic?
What are you going to do on that wall anyway?
Edited by wolflet
got+pic?+What+are+you+going+to+do+on+that+wall+anyway?
Normally I will take photo but this round forgot. After removing the wall titles, I'm going to plaster and paint it + install windows. For external wall damage, I'm lost.
what do u mean external wall damage? the damage is on the outside? not in your house?
PS. sorry about the cranky reply just now, HP is running crazy.. auto add +s
No worries, is ok. Ya man, damage on outside, if the external brick fall off, it can be fatal. I will go and take photo this evening.
This is the photo of the broken brick @ external wall... My ID says he will fix it back for me.
Some updates after 1 week of reno...
Common Toilet tiles up halfway liao. Water proofing 1 layer, total got 3 layers.
Kitchen Tiles up half way too...
Corner for full height Shoe Rack, which I didn't expect it to be so big...
Edited by sunnytan31
don't worry la. ur shoe cabinet not that big. mine is 7 ft
My fully populated 22-way DB box cost me abt $140 whereas compared to fully populated 14-way DB box quoted by ID was $400. Guess I have squeezed lots of saving by DIY-ing electric. Currently outstanding items are 1.5mm cables, 2.5mm cables. 10mm cables, Coaxial and PVC casings, budgeted ard $300.
Got all my electric switches @ Choo Chiang, Toh Guan Branch.. Everything below cost me $605.
1 Hokey CAT5e UTP Cable (300m) - 1 box
2 CCM Switch Base - Single - 30pcs
3 CCM Switch Base - Double - 35pcs
4 Legrand Mallia 10A Switch - Single (White) - 1pc
5 Legrand Mallia 10A Switch - Double (White) - 3pcs
6 Legrand Mallia 10A Switch - Triple (White) - 4pcs
7 Legrand Mallia 10A Switch - 4 gang (White) - 6pcs
8 Legrand Mallia 20A Switch - Water Heater (White) - 4pcs
9 Legrand Mallia 13A 3-Pin Socket - Single (White) - 1pc
10 Legrand Mallia 13A 3-Pin Socket - Double (White) - 29pcs
11 Legrand Mallia 15A 3-Pin Socket - Single (White) - 1pc
12 CCM 20A Electric Rose - 3pcs
13 Legrand Mallia Coaxial Outlet (White) - 4pcs
14 CCM 22-way DB Box - 1set
15 Hayer 2-Pole 32A MCCB - 1pc
16 Hayer 40A ELCB - 1pc
17 Hayer 10A MCB - 6pcs
18 Hayer 20A MCB - 12pcs
19 1M Copper BusBar - 1pc
20 20mm Hammer - 1pc
Update! After 2 weeks of reno.....
Tiles so far I very happy, no complain or anything. Good workmanship, hope he can maintain for the rest of my flooring...
Living Room Tiles
Kitchen
Original quotation was $33k but after adding...
1) Doors work - due to the gap between flooring and doors - $200
2) Windows - decided to change all to Casement - $3700
3) 5ft Full Height shoe cabinet - $1150
4) Mosiac tiles addon in both toilets - $150
5) Concrete support @ kitchen area - $1100
6) Fix and conceal casement aircon opening with alumin frame and parition board - $150
And other miscellaneous addons, so till date the BOMB is $42k. @_@
I need some knowledge sharing on curtains. My wife and I decided to install those wooden rod curtain for LR and all BRs.
Is there anything to note when shopping for wooden rod?
The reason for this qns is bcos over last weekend, we went 3 place to research on the rod and realise price varies alot.
1) Giant @ IMM, 7ft rod alone w/o accessories - $27.99
2) Spotlight @ Plaza Sing, 7ft rod w/ accessories - $74.90
3) Gek Poh Hardware Shop, 7ft rod w/ accessories - $17.00
Pls advice and recommend.
Thx..
