terenceyyk
Water Feature Location
Hi all,
i have been reading the posts about feng shui and water feature location, could anyone enlightened me is the position of my water feature in the correct place in my living room?
from my research in the net, i know is in the * area is where the wealth spot is but i'm still confused.
i have attached my floor plan in the picture with the water feature placing in the area but i just want to confirm is the area correct?
please enlighten me...
Terenceyyk
Hi all,
Terenceyyk
I won't recommend you put water feature if you don't know it is the correct position. Must be safe. If u put at the wrong place, the problem will be serious. Also I realize your main door facing window directly.
Right, water feature cannot anyhow put......
hi,
can u enlighten me more on my main door facing the window directly?
is this very bad for my water feature?
hi,
you need to contact a fengshui master. I am not one. I just know if main door face window directly, the qi flow is no good. I suggest u consult a fengshui master else wrong water feature position might be a prOblem
