TimWong
Air-con Group Buy
Hi Tim,
Good day!
Can you pm me the quote for
1) Mitsubishi Starmex/heavy Industries Inverter Sys 3 w installation.
Please advise your Insulation type, copper piping and water piping used.
Thanks!
Looking for installations quotes too..
*Will rent out room...so need them to tahan abuse by "ppl" long..... :notti:
Mainly need is 又便宜,又好。。。
House 1 [4 rm BTO]
1) 9k BTU x 3
2) 9k BTU x2 + 12k BTU x1
House 2 [5 rm BTO]
1) 9k BTU x 3 + living room
2) 9k BTU x 2 + 12k BTU + living room
Both flat same block so easier for you too..
*Do advice outdoor unit is how many BTU.
Thank you very much.
Please quote suitable inverter system (3 different brands for comparison) for EA with following configuration:
3 rooms + 1 study
and
Living/Dining/Corridor area
Thanks!
Dear Tim
Could you provide me with recommendation for System 4 air conditioner?
Below are some of the information to help you recommend:
Flat Type
4 room HDB flat @ Punggol
Brand
Mitsubishi or Daikin
BTU
- 9,000 BTU for 3 bedroom
- 18,000 BTU for living room
other things to note:
- 2 trip installation
- 1/2" armaflex (Class 0 or 1 PSB certified insulation)
- G23 copper (what is the length used?)
- 16mm PVC water drainage piping (unlimited piping & trunking)
Recently, I had engaged Tim to do Air-Con installation for my new flat. He was a friendly chap who gave me advises on where to place the air-con and what to look out for. He also made the effort to liaise with my ID for the air-con installation. The piping was neatly laid and the air-cons are covered to protect them from dust. Overall. it was a pleasant experience.
Dear Tim
Please quote for System4/5. Toshiba or starmex is
Flat Type
5 room. But used to be 2 3 room combine by government. 4 bedroom. Master rm bigger then normal.
Brand
Mitsubishi or Toshiba
BTU
- 12'000 BTU for maater
- 12 or higher for living.
- 1/2" armaflex
- G23 copper
- 3c70 outdoor, 3c40indoor?
Bracket maybe if you could reuse. But the wooden panel board need to change. 15 amp socket already installed.
Trade in. Mhi s4.
I went to gc but don't like their attitude. Kindly give best cost for s5 , will seriously consider if attractive.
And pls advice mode of payment. Any cc installment.
Cheers
Cueball15@gmail.com
Pls provide recommendation for 5 rm flat. Going to combine MBR with bedroom 3 so thinking of the following
Option 1
Living 18k btu
Bedroom 2 9k btu
MBR 18k btu
Option 2
Living 18k btu
Bedroom 2 9k btu
Bedroom 3 9k btu
MBR 9k btu
