TimWong
Air-con Group Buy
Hi Tim,
any promotions now for either inverter system 3 or inverter system 4? pls quote prices with installation, brackets etc.
mines a 5room HDB with 3 bedrooms & 1 study. about 127sqm. what would you recommend?
thanks
hi guys.. is this group buy still available?
my parents gonna change my old system 3 carrier to some new system 4.. not sure what brand.. am interested.. so do contact me...
9eight0692one0
hi,
are you from the same company as Aron?
can you quote me Mitsubishi Electric Starmex , Mitsubishi heavy industries and Panasonic eco-navi system 3 pls?
thanks.
zzlp@ymail.com
Hi, Tim,
Greetings!
I have decided that the drain pipe should be 16mm and would consider having 2 sets of 2 in 1 system to balance up the load.
Please quote me the following system:
Mitsubishi Inverter System - MXY3A28VA (Outdoor unit) x2 / MSYGE10VA x 4
Panasonic Inverter System - CU-3S27MKZ (Outdoor Unit) x 2 / CSS9NKZW x 4
Include Armaflex 1/2 Inches Class 1 Insulation and 16mm PVC drain pipe.
Instead of copper pipe for the gas pipe, could you install aluminium pipe?
So I am using a 3 in 1 CU to drive 2 FCUs. Or should I use a 2 in 1 CU to drive 2 FCUs?
I could not decide whether to go with Mitsubishi or Panasonic system. Which country are these systems made in?
Thank You and Best Regards
Hi Tim
Appreciate that you can provide quote on the following
Mitsubishi Electric Starmex System 3
Panasonic Eco-Navi System 3
- 16mm drain pipe
- Armaflex Class 1 insulation
Thank you.
