vermyapre
Electrical work cost??
Hi all,
I have an urgent query and hope you can help me.
If I want to change the DB box for my resale HDB flat, should I rewire the whole house at the same time? Or can I just simply change the DB box without any rewiring?
What's the correct way to go about doing it?
Please advise.
Thank you!! :D
I just got my old friend to quote at this price, is it cheap good enough?
To change the new switches $5.00 x 41
To install new lighting point $25 x 14
To install light fitting(downlight) $10 x 10
To install normal light fitting $8 x 14
To shift SCV TV point $80 x 1
IC for lighting $20 x 1
Total : $867
The quotation u got was cheap leh !
Is it becoz it's ur old friend that is why u get gd rates ? Wat if u recommend to pple like me (desperately looking for cheap electrician) ?
Is can get gd rate, pls share his name & contact number ?
Thk u :)
Hi, I have the same question as mercey actually. Appreciate replies.
Btw, here's what my ID quoted me. Waiting to meet up tomorrow because I think some items are overpriced.
a. light/ceiling fan points – 2 nos. @ $50 = 100
b. 13A twin SSO – 3 nos. @ $60 = 180
c. heater switch for hood / hob – 2 nos. @ $60 = 120
d. heater pt – 2 nos. @ $100 = 200
e. SCV point – 1 no. @ $120 = 120
f. remove and install only new light fittings (exclude chandeliers) – 12 nos @ $15 = 180
I have not even included telephone points and extra single/ double points or change the switches in the quotation. So not sure how much is the additional charges.
Hi all,
I was quoted:
- Hood point: $75
- Build-in oven point: $75
I think it's on a high side, wat do u guys think ?
BTW can sum1 explain wat is "light fitting" and the difference between "concealed" & "non-concealed wiring" ?
Thank you.
Edited by aerial77_00
Hi all,
I was quoted:
- Hood point: $75
Thank you.
i did mine at 55 for hood
light fitting- can be any light that u buy.
concealed -need to hack n hide the wire, not for hdb
non-concealed- with casing cover type, for hdb
btw.. just share my quote
light pt-25
double socket-50
scv-85
heater-80
air-con-80
hoob-55
tel pt-40
2 way switch-30
mcb-300
supply n install 2x13A PLC light fitting-30
Thk u :)
Hwah so cheap, its a good friend to have hehe :D
I just want to change the cover for the power sockets as they look old and wld look odd with the new kitchen cabinets.
But the quote I was given sounds so exp -
$60 for single power socket/ $80 for double.
Why so exp when all I need is to change the exterior? Was told they got to do re-wiring even when change cover only..
Is it true? Can I get better rates than quoted?
Thanks!
hi all, u mean e hood e electrical is done by e electrician? not done by e hob & hood supplier when they deliver to u ah??? & what's e normal rate for it ah? :D
Total : $867
hi,
Possibe to share ur frenz contact.
Looking for electrician urgently....
Total : $867
Can I know what does it mean by Shifting SCT TV Point? I thought we are not supposed to temper with the SCV Point - there's this sticker on the cable point?
Pls enlighten.. thanks...
any help pls ? & in addition how to tie in with the installation of kitchen cabinet ah??? help
