vermyapre
Electrical work cost??
Hi Guys
I was quoted the following for concealed wiring
1 X 5A = $60 ( inside false ceiling $50)
1 X 13A = $90
2 X 13A = $110
Tel pt = $110
SCV =$200
1 X 20A =$280
D/B = $1200 - $2000 (depend on amt of way)
Install lights fitting = $10/pc
is it reasonable?
Thank you.
Hi Guys
1 X 13A = $90
2 X 13A = $110
Tel pt = $110
SCV =$200
1 X 20A =$280
is it reasonable?
Thank you.
Anyone any advise?
thanks!!
I just got my old friend to quote at this price, is it cheap good enough?
To change the new switches $5.00 x 41
To install new lighting point $25 x 14
To install light fitting(downlight) $10 x 10
To install normal light fitting $8 x 14
To shift SCV TV point $80 x 1
IC for lighting $20 x 1
Total : $867
Total : $867
It cheap enough.
Total : $867
He is your good old friend wah :bangwall:
i just got my quote last week.
$33 per lighting point... bleahx. :curse:
imagine 17 lighting points that could have been $25/ea => difference of $136 already!
am asking for a discount off the quote.
Edited by firehorse
Hi all
Need help, pls help check if my electricity quote ( all concealed wiring) is fair?
revised...
single 13amp power pt $50
double 13amp power pt $55
change 13amp power pt $15
scv pt $90
tel pt $60
install ceiling fan pt & fan $85
install ceiling fan $35
2way heater pt $110
relocate a/c power pt $34
wiring & install lighting pt $35
whts e difference between SCv pt , Scv spltter ( can jus buy on my own & affix rt?) & Cat 5E data pt ( isnt it e scv cable pt used to connect scv cable modem??)
if there is already 1 lighting pt,,, then loop to create 2 lighting pts - considered as looping light point???
any feedback greatly appreciated
Tia
fini
Edited by fini
below is what ID quoted me this for Electrician work, i feel is so ex lor bangwall.gif
anyone can intro me same reliable Electrician? need to rewire the whole house on the 28th oct follow the schedule from my ID
Dining Light $45
Heater point and switch $90
13amp double point $58
13amp single point $45
Telephone point $55
15amp Air-con $90
Lighting installation $5
Hood and Hob connection $30
SCV point $120
Light gang $28
DB Box $280
Water earth $70
called Eric tat forum recommended still no reply from him i'm so worry now, need to confirm everything asap
Dining Light $45
Telephone point $55
15amp Air-con $90
SCV point $120
Light gang $28
DB Box $280
Water earth $70
Conceal or not conceal?
not conceal
For electrical wiring, I don't think your ID earning much for this..even intro u electrician, the most u can save is ard $100...so u still want a electrical as you need to coordinate yourself for it?
Hi guys,
can anyone advise me what is the charges for the electric works for a new 4-room flat, i think the flat come with concealed wiring if I am not wrong. Do u think its necessary to do any rewiring? Pls advise me on what is a reasonable quote for some of the work done for new flat?
Thank you
can anyone tell me is this quotation okay?
Dining Light 45 x 1
Heater point with switch 80 x 1
13amp double point 50 x 10
13amp single point 40 x 2
Telephone point 45 x 1
15amp Air-con 70 x 1
Lighting point 33 x 16
Hood and Hob connection 30 x 1
SCV point 90 x 4
DB Box 250 x 1
Water earth 35 x 1
Not conceal wiring
My ID quoted me everything all in plus rewiring $2100, is it price cheap or average?
Edited by francine
