vermyapre
Electrical work cost??
  On 12/1/2017 at 8:21 AM, hellolulu said:
Hi. may I know if the attached quotation from the electrician is considered reasonable? Thank you.
My electrician's quote
  1. 13A double power point $60ea
  2. 13A single power point $55ea
  3. 15amp aircon power point $95ea
  4. 20amp water heater point $95ea
  5. SCV data point $90ea
  6. Lighting point $30ea
  7. 16 way D/B switch box $320
  8. Install light fittings $15ea
  9. Earth point $100
I got a quotation as below.
Am I getting chopped? :wacko:
1. Lighting point $40ea
2. 13A double power point $75ea
3. SCV point $120ea
4. Data Point $180ea
5. hood point $140ea
6. Oven point $155ea
7. 20 Amp Industrial hob point $250ea
8. Install hanging light $65ea
9. Install light $10ea
10. Install T5 $10ea
11. Conceal and hacking works $400
  9. Earth point $100
Hi, can PM your electrician contact? Your rates include the hacking and concealing is the wiring? Thanks.
Dear Cadino,
Please email me. I can assist you
samsim@jianye.com.sg
Thank you
Does anyone knows how much it cost to do the following electrical work for a 4-room HDB BTO flat?
1st trip
  • Provide Materials & Labour to extend existing water heater electrical wiring in common toilet to service yard and install new water heater outlet and switch at service yard.
  • Provide Materials & Labour to lay 2x new 15 amp cable from MCU to Kitchen (~5m and ~8m) with switch at a different end.
    MCU ---- Switch ---- Electrical port
2nd trip
  • Install water heater tank in service yard
  • Install ~13x LED ceiling lights
  • Change 2x 2-Gang plug outlet to a new outlet (plug outlet provided)
  • Change 1x 2-Gang switch to a new switch panel (switch panel provided)
lighting point=$30 13Ax2=$55 13Ax1=$45 water heater=$85 scv=$85 tel=$40 data point=$100  15A(aircon)=$90 intall light=$10 intall fan=$50        lighttig point conceal=$55   single socket conceal=$70  double socket conceal=$80  tel point conceal=$55  data point conceal=$130        hv any probluem for electeric can sms him hp:84559198/+60127666950 whatapps:+6584559198
