vermyapre
Electrical work cost??
Hi All, I got a contractor for Condo electrical works. Please advise is the price reasonable?
1) 13amp Single power point = $55
2) 13amp Double power point = $65
3) Lighting point = $35
4) Telephone point = $55
5) Cat 6 data point = $120
6) SCV point = $120
7) Lighting Installation = $10
6) SCV point = $120
The price look reasonable to me.
Hi All, my ID quoted me these prices. Can advise is the price ok?
lighting point $45
installing lights $12
installing celling fan $50
installing LED + driver $70
13 amp power point (twin) $70
13 amp concealed twin $95
13 amp concealed sgd-dbl $95
scv point reposition $50
tel point reposition $50
data reposition $50
install of tel and main data $150
data point concealed $150
lighting point $45
data reposition $50
hi there,
im a reno contractor by occupation, and i can honestly and sincerely tell u that your electrician is definitely giving you a good price.
avg he's only earning $10+ per installtion, which is a reasonable price.
Prices have increase across all board of stuffs in renovation works, which includes electrical works, even masonry works.
hazardous, on 08 Sept 2015 - 08:13 AM, said:snapback.png
lighting point $45
data reposition $50
can i have the electrician contact? i am getting my BTO keys soon
the prices for electrical installation from my quote
13amp single 45
13amp double 55
light point 27
cat 6 90
scv 90
tele 40
hob point 75
20amp isolator 120
install ceiling light 10
install fan 40
install heater 40
install switches 25
my contractor is a GST company wor which mean even Non GST company are charging more than a GST company??? please ensure the price before consumer get kill on variable orders which we HATE MOST $$$$
Hi all,
Can i check if my below electrical quotations are considered reasonable? Thks
1
To supply labour and install 13Ax2 power point
75.00
1
75.00
2
To supply labour and relocation 13A power point
50.00
4
200.00
3
To supply labour and install lighting point
45.00
14
630.00
4
To supply labour and relocation SCV point
85.00
2
170.00
5
To supply labour and relocation DATA point
85.00
1
85.00
6
To supply labour and install Hood and Hob point
75.00
2
150.00
( c/w: 20A heater switch control )
7
To supply labour and install looping point for T-5 light
25.00
20
500.00
8
To supply labour and install ceiling light (7) and T-5 (24)
12.00
31
372.00
9
To supply labour and install ceiling fan
45.00
1
45.00
10
To supply labour and install 20A OVEN point
125.00
1
125.00
11
To supply labour and install hanging light
45.00
2
90.00
12
To supply labour and relocation lighting point and lighting
30.00
8
240.00
switch
13
To supply labour hacking and plaster wall for electrical
380.00
1
380.00
14
To supply labour and install 13Ax1 power point
65.00
3
195.00
15
To supply labour and install two way lighting switch
50.00
2
100.00
16
To supply and install dimmer switch
35.00
1
35.00
17
To supply labour and install LED strip
15.00
5
75.00
Hi, recently just get the key for my new flat. It our 1st time doing reno, as our tight budget every spend must be wishly :no:.
Happen to know this electrican thru my friend, Hereby is the quote from him, compare to other seen at forum is it reasonable?
He have given me 3type of diff brand switch to choice- MK, schneider & hager. which brand is most common use? Usually do they include of supplying the light?
1. Supply & install 2x13A power socket- 12nos x$50 =$600
2. Supply & install 1x13A power socket with water-proof cover- 2nos x$55 =$110
3. Supply & install lighting wiring point c/w switches- 21nos x$30= $630
4. Installation of LED downlight- 16nos x$8 =$128
5. Installation of surface ceiling light- 5nos x$10 =$50
6. Supply of 9w LED downlight- 16nos x$20 $320
7. Supply & install ceiling fan point- 1nos x$35 =$35
8. Installation of ceiling fan- 1nos x$25 =$25
9. Supply & install oven, cooker & hood wiring point- 3nos x$55 =$165
10. Supply & install heater point- 2nos x$65 =$130
11. Supply & install 15A A/C power socket- 1nos x$90 =$90
12. Supply & install SCV point- 3nos x$60 =$180
13. Supply & install CAT5e data point -2nos x$60 =$120
14. Supply & install 16way PVC DB & ness circuit breaker- 1nos x$320 =$320
15. To dismatle existing electrical item- F.O.C
  • Like 1
Hi guys,
When I buy a hob and hood, who will be doing the installation for me? Contractor or electrician or the hob/hood seller?
Thanks!
  On 11/22/2015 at 1:32 PM, Del8 said:
Hi guys,
Thanks!
normally will be the contractor. it should be part of the quote. fyi he needs to take measurements of the hob and hood in order to fabricate the kitchen cabinets.
Thanks! Means I need to buy my hob/hood before I start my discussion with the carpenter for kitchen cabinet?
ya that was the case for me. My contractor worked out a proj schedule and told me by when i need to buy the hob/hood so that they can take measurements for the carpentry based on the actual dimensions. Best to check w ur contractor/id.
