vermyapre
Electrical work cost??
I'm also looking for electrician. Correct me If I'm wrong. Thot for down light, only a few light point needed, others are calculated as "loop" point? cheaper
I just bought an 11-years old HDB flat (5-rooms flat type 5A).
My questions:
1.Do I need to do rewiring if the previous owner never change the wiring before?
2.How much is estimate cost of rewiring for the 5-rooms flat?
3.Any recommended electrician to do rewiring?
Thanks.
Hi people, my three room wiring quote
Is this reasonable?? Need to confirm ASAP
Hi
Can PM me your elect's contact? the last 4 digits, is it 0031 or 0631? Thanks in advance
Edited by andrewlimhb
1) you're right, installation of downlights are priced on top of the cost of 'pulling' the new point.
2) my electrician did not charge me for the cost of switches and powerpoints (normal MK brand). Maybe you're opting for those designer types of fanciful switches??
Hey Ken, mind sharing your electrician contacts. Perhaps you could share your quote too. Thanks!
Hi Everyone,
I'm new to this forums, like to seek your kind advise on whether the quotation by my ID's Electrician for my 5rm resale hdb flat is reasonable?
1) 31 x Supply & install Lighting Point using 2x1.5mm PVC cable + 1x1.5mm PVC earth cable in PVC trucking /conduit @ 31x$38 = $1,178
2) 11 x Supply & install Looping Lighting Point using 2x1.5mm PVC cable +1x1.5mm PVC earth cable in PVC trucking /conduit @ 11x$35 = $385
3) 37 x Installation of Light Fitting @ 37x$10 = $370
4) 01 x Supply & install 1x13A using 2x2.5mm PVC cable +1x2.5mm PVC earth cable in PVC trucking/conduit @ 01x$50 = $50
5) 05 x Supply & install 2x13A using 2x2.5mm PVC cable +1x2.5mm PVC earth cable in PVC trucking/conduit @ 05x$60 = $300
6) 01 x Supply & install 2-Way Heater Point @ 01x$120 = $120
7) 01 x Supply & install telephone point using 6core wire @ 01x$60 = $60
8) 01 x Supply & install cooker hood & hob point with heater switch @ 01x$70 = $70
9) 04 x Installation of ceiling fan @ 04x$50 = $200
10) 08 x Shift & install 2x13 S.S.O @ 08x$35 = $280
11) 03 x Supply & install SCV point using RG6 cable @ 03x$70 = $210
12) 01 x Shift & install Telephone Point @ 01x$35 = $35
13) 04 x To change switch @ 04x$30 = $120
Gross: $3,378 (w/o gst)
Total: $3,614.46 (w gst)
Your kind advises is greatly appreciated! :)
If you guys need a quote, no harm asking mine.
My current electrician is very good!
On time, flexible nice and good pricing!
Thomas- 92375535
very normal mah. our resale 5-rm whole unit rewiring cost us $3075 :thumbs up:
unit prices as below:
Lighting point $28
13A Single power point $38
13A double power point $48
SCV point $85
New telephone point $40
Heater point $80
Install light $8
Dimmer $40
2-way switch $40
Install Doorbell $15
MDB box $300
Aircon point $80
hi, cornetto,
can pm me your contractor's contact?
thanks
Hi
Hi, did you in the end get the contact? How's the electrician, if u don't mind sharing. I'm looking for one urgently....as my electrician who's recommended by my ID is completely crap...... :~
Hi all, i juz got a quote from the electrician by our ID company. As i'm a newbie to all these, can i ask you guys is this quotation below overpriced?? Thanks!!!!
Living room
Supply n labour lighting point(with installation) 10x$45
Installation of lightings 7x$10
Installation of ceiling fan 1x$60
Labour to conceal wall for light 2x$100
Supply n labour cat6 point 1x$200
Bedroom 2
Installation of celiling fan 1x$60
Master bedroom
Supply n labour lighting point(with installation) 6x$45
installation of lighting 3x$10
Supply n labour ceiling fan point with installation conceal 1x$120
labour to conceal wall for light 1x$100
Kitchen
Supply n labour cooker hood point conceal 1x$90
installation of lighting 2x$10
2 toilet + store
Installation of lighting 3x$10
Living room
Bedroom 2
Master bedroom
Kitchen
2 toilet + store
Abit more costly by a few hundred ba... Anywayz you got do other reno works too right?
